Wideband gauge from Enjuku in FL
I found these guys out of Florida. They are selling the AEM UEGO for $199.80 including shipping to Canada. This is the best price I have seen so far especially considering they cover the shipping to Canada. I think it is a pretty good unit overall from what I have read, has anyone here ever dealt with them before?
http://www.enjukuracing.com/gaugetyp...dfe564fab9fbb8
One of my problems with some of these cheaper widebands was they don't have the capability to log AFR *and* RPM. IMO logging both is required to do proper tuning. Most would allow you to add RPM logging as a module with a bunch more $$$. Now, if you are getting a sharktuner, you can use that for all your logging needs, but if not I would recommend you go with the cheapest setup that logs both AFR and RPM.
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Rocket Pilot
Dan the uego allows this and much more. I've been running one for 2 years. It is not one of the "cheaper ones" as many, many tuners use it for it's price and capability/reliability.
Keep in mind all wide band controllers are not created equally. Here is a repost of a comparison test run a while backfrom fordmuscle.com.
http://www.innovatemotorsports.com/r...B_Shootout.pdf
However, the AEM you are looking at seemed to test pretty well.
FYI, the absolute cheapest was JAW http://www.14point7.com/Widebands/JA.../JAW_1_041.htm. However, the gauge display was too raw for my tastes.
Dan
'91 928GT S/C
Dan
'91 928GT S/C
I had the Zeitronix in my 951 and it seemed to work just great. After about 2 years I had to replace the bosch sensor. The data logging was very useful when tuning with a MAF voltage massager. My only complaint is that the wires in the harness provided with it are too small and easy pulled out of or broken at the connector. The innovative seems to be the most popular.
The Zeitronix and the MAF tuner I had both could hear the noise from the plugs in the 12V source, you just told it how many cylinders you have. The eBoost boost controller I wanted also used ignition noise to sense rpm.
Dan
'91 928GT S/C
FWIW RE: the JAWs, we have one in our local club that consistant reads 0.06 leaner than true when compared against a calibrated wideband on a dyno. I suppose its good to err on the side of caution (i.e. the car is actually running 0.06 richer than the guage shows).
I realize this is purely anecdotal - being based on only one unit.
As far as TechEdge, I wish they had run that in the comparison. I run an old TE version 1.5 in my track car.
