928 Forum 1978-1995
Sponsored by: 928 Specialists
Wheel Sizing
Old Feb 3, 2010 | 07:43 AM
stuartph's Avatar
stuartph
OJ
Have you looked at CCW wheels
On the front hub the bearing cup sticks out, with my ET50's and 65's the cap has to have its shoulder cut down so it doesnt stick out as far, but dont cut to much as it will rub on the bearing parts
Old Feb 3, 2010 | 08:13 AM
OJ GTS's Avatar
OJ GTS
I have now... Hmmm, the styles nearly as good and the wheels will cost just over half as much with the exact spec I need. That's pretty tempting!
Good find
Old Feb 3, 2010 | 08:20 AM
stuartph's Avatar
stuartph
OJ
I did a thread on them last year
They are on a long list of parts i'll be after this year
Old Feb 3, 2010 | 09:15 AM
OJ GTS's Avatar
OJ GTS
Just had a look at the thread, fire me a pm/e-mail if you think they might do a deal for a double order!
Old Feb 3, 2010 | 12:41 PM
FredR's Avatar
FredR
Originally Posted by OJ GTS
Thanks for the replies Fred and others!
I'm not looking to go for maximum tyre width, in fact I'm quite happy to use the minimum width tyre possible without 'stretching' it, which I'm led to believe is a 255, although a 265 would be preferable. Does anyone think that is going to give me a problem?
Also Fred, when you say bearing cap, do you mean the flange that sticks out from the centre? In which case, those BBS wheels are stated as Porsche fitment with the appropriate bore centre (i.e. the hole at the centre of the wheel), is the 928 different to other Porsches in that respect?
Thanks again guys, this is all really helpful
OJ,
I am talking about the push-in cover that encapsulates the front wheel bearing housing. If you do not know the answer to this point then you certainly need to as you do with respect to clearance over the brake caliper. I repeat- do not assume the wheel supplier knows the 928 geometry- it is different. The only things in common with other Porsches is the 5x130 stud configuration and the centre trims. The wheels I have were originally intended for a 911 and configured for a 928 but do not fit a 928 correctly. I could machine the inner hub of the wheel but even so, the centre cap would still not fit because of the restricted height.
If you look at the front stock wheel you will see that it is a very close fit to the caliper. The 928 geometry requires the front wheel to be pushed in to the wheel arch which is why other Porsche front wheels do not fit the 928 correctly.
Also, you might be able to fit a 255 on an 8.5 inch section but with that offset I would be surpised if you did not have interference problems with the inside of the front wing.
I am not suprised about the condition of London roads but I am surprised that the stock wheels could not handle it. For sure, if they have problems then modular wheels will have more problems- but they can be fixed. When you select a wheel type try to ensure that they are made from 6061[?] series ally rather than 5000 series which is weaker. Also check the rim thickness to ensure they are more road oriented rather than the thinner track type rims which buckle very easily. I think the track type are about 4.5mm thick whereas the street type are something like 6mm thick, maybe a bit less. Others can advise you on that.
Regards
Fred R
Old Feb 3, 2010 | 12:51 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
I have two sets of factory Cup1's and one of the rears on each set has had a crack in the inner rim. Greg Brown has seen the same thing on multiple sets. I have had both sets repaired and are fine given the good roads around here, but I'm keeping an eye on them anyway.
Old Feb 3, 2010 | 01:18 PM
OJ GTS's Avatar
OJ GTS
The thing that sways me is the fact that the BBS website specifically lists the sizes of RS-GT for the 928... I know it's not a great thing to rely on, but is it a coincidence that the part numbers are RS927 and RS928H?
Having said that i've just had a look for some images of the front suspension and I see exactly what you mean. I'm reasonably confident that if the wheels would clear the brakes on, say, a 996 then they'll clear the brakes on a GTS, but that hub cover is pretty chunky. I think I need to get at mine and see what the shape is underneath... The other Porsche models seem to just have 3 teeth sticking out whereas the 928 has a great big lump of hub! Thank you negative kingpin offset suspension.
And sorry wasn't being clear, the 255 or 265 would be for the rear, not the front!!
Yep, the inner rims have cracked more than once, albeit all when my father owned the car. The roads really are that bad. We've been given the option of welding them up in the past, but never taken it and always bought new wheels.
And good point with the rim thickness, I know how easily track rims bend, I went through about 10 of the bloody things on the racing car last year, half the time it was like driving a shopping trolley with a wonky castor
Old Feb 3, 2010 | 04:55 PM
Rob Edwards
Archive Gatekeeper
I'll have to wait till I can take a pic to illustrate, but the front hub dust caps on a GTS (well, at least my '93 GTS) are considerably 'lower profile' than those on all other 928's 1978-1991 (911 341 684 00) , despite PET showing this same part number for all 928's 1978-1995. I learned this the hard way after buying the proper Porsche 9165 tool to remove them. It doesn't work on the GTS 'cause there's no 'divot' to grab into.
Since you have a GTS you may be in luck on this point, or maybe not. Since PET doesn't mention a different #, it's impossible to tell what you've got.
Anyway, I know lots of people just hammer in the dome on the dust cover on earlier cars to make center caps fit, but if you can find 'em, the GTS hub covers might be a more elegant solution.
Pictures at 11.
Old Feb 4, 2010 | 04:23 AM
OJ GTS's Avatar
OJ GTS
I'll have to check that one out, my GTS is a very late model (one of the last 20 RHD) so chances are if there's an upgraded part, it'll be on there
Thanks again!
