STEERING WHEEL FITMENT 1990S4
Does any members know if this steering wheel part number will fit on a 1990s4. 944 347 804 50 FFF-My old wheel part number is 944 347 804 51 AJ.
Last edited by RED SHARK 1990; 02-02-2010 at 12:33 PM. Reason: misprint on part number
Team Owner
I would say yes it should fit the letters are code for the wrapping of the wheel
I need to correct the numbers on the part. The new wheel have not purchased yet with-944 347 804 50 FFF-My old one is 944 347 804 51 AJ. Can members chimed in before i make the purchased only to find out it does not fit. Porsche part department could not tell me....
Team Owner
if they have the wheel have them measure the inside of the wheel for the shaft opening and you do the same on yours
I'm not sure about part numbers and fitment but I have just been replacing the baskets under the steering wheels (non air bag) they are only held on with 4 rivets just carefully grind them off. Use the original basket and splines and rerivet onto the new steeringwheel. 3 spoke and 4 spoke wheels use the same basket so swapping them is easy. Not sure if that will help you but good luck.
