My timing belt job
#31
Shameful Thread Killer
Motor mounts are the best cost investment now. It's a messy job, but really helps the ride. Nice looking work.
#32
Pardon the hijack ... I was fantasizing today about buying another 928, which happens to have had a recent TB job.
So it made me think, could one pull the lower cover off and just switch out the original Porsche tensioner with a PK (and associated parts) and never take off the belt?
#33
Inventor
Tom, after you give the a/c some slack you barely have room to remove the lower cover with the pulley still in place but I have done it. The t/b is a cheap insurance at less than $30, why not change it just for the extra piece of mind?
#35
Done.
Whooohoooo!!!!
Got everything buttoned back up and fired her up. No problems.
No leaks. There was the expected lifter noise on startup and it did smoke a little more than expected for the first 15 seconds or so, but everything seems to be working.
Took her for a short shakedown drive and temp stayed normal. I did not notice a big change in performance, but she always did feel fast before. If anything maybe just a bit smoother.
Brakes feel great. The new rotors have eliminated the pulsing when hot.
So, now it is time for a more extended drive to really have fun again.
Thanks for everyones input.
Whooohoooo!!!!
#37
Nice job!
A new belt will stretch to create around 2° retard on the 1-4 side (<1 on the 5-8), about the same as a cold to hot engine. You should verify your settings after 1000 miles or so. With a 1K+ mile belt, add ~2° retard to the 1-4 side when cold, or set both sides the same when the engine is hot. With a new belt, set both sides the same, cold.
I will check again when the starter will be back on.
Raphaël
#38
Just make a note of whatever timing values you set today and you should find that the value on the 1/4 bank will retard by about 2 degrees from such position after the 1000 mile settle in period.*
#39
Thank you for your feedback Fred. I will check after starting the car and then after 1000/1500km. I will adjust if necessary at that time.
Raphaël
Raphaël
