928 Forum 1978-1995
Sponsored by: 928 Specialists
CIS feul distributor
Old 01-11-2010, 10:03 PM
tailpipe
tailpipe's Avatar
Default CIS feul distributor
Does anyone know if there is a difference between the aluminum bodied vs the cast iron bodied fuel distributors I have both here ready for rebuild just wondering if I should bother with the aluminum one?
thanks
Paul
Old 01-12-2010, 09:50 AM
Dennis Wilson
Dennis Wilson's Avatar
Paul,
Is the aluminum bodied distributor off a MB? If so, it probably has individual adjusters for each injector. Pictures?
Dennis
Old 01-12-2010, 03:32 PM
danglerb
danglerb's Avatar
Pictures showing part numbers maybe?
Old 01-12-2010, 09:17 PM
tailpipe
tailpipe's Avatar
yes the aluminum fuel distibutor came off MB i have seen a picture of a 928 with one being used so i'm assuming its the same just looking for conformation before i spend time working on it
Old 01-12-2010, 11:11 PM
Dennis Wilson
The biggest differences between the MB fuel distributor and the 928 are (1) the individual adjustments for injector pressures and (2) the gasket between the two halves is rubber rather than stainless steel. They should be a good replacement for ours but the new and rebuilt prices are much higher.
Dennis
Old 01-12-2010, 11:53 PM
karl ruiter
karl ruiter's Avatar
No, MB part is not worth your time. Send it to me.
Old 01-13-2010, 06:50 PM
tailpipe
tailpipe's Avatar
the shipping would prolly be more than its worth karl especially if its going to HI
Old 02-09-2010, 11:41 AM
Fabio421
Man of many SIGs
Fabio421's Avatar
Which MB cars had this adjustable distributor?
Old 02-09-2010, 11:58 AM
rjm65
rjm65's Avatar
Can the gasket from the MB FD be retrofitted to the Porsche FD?
Are the spring/caps found in the individual chambers on the Porsche FD not used on the MB as you have the individual adjustments?
http://cgi.ebay.com/ebaymotors/BOSCH...#ht_500wt_1182
Old 02-09-2010, 12:00 PM
Dennis Wilson
Their V-8 engines, up to 1995, had the adjustable injectors ports like the 931's.
Dennis
Old 02-09-2010, 12:09 PM
Dennis Wilson
The shape and size looks the same but using a thicker rubber gasket (MB) may change the calibration of the springs. IIRC the adjustment is via needle valves that control the volume to the injectors. i.e. they may work but would require some fine tuning.
The MB unit still has the springs and caps. That is what deformed the rubber gasket pictured (second picture) on ebay.
Dennis
Old 05-28-2014, 11:45 AM
Fronkenstein
Fronkenstein's Avatar
450, 500. Euro one is the one to get if you can. They run about $90-100 and the cost to rebuild isn't any more than the cast iron one. They are easily cranked up by adjusted they flow circuitry - hence no magic to it. Talk to Larry at CISFlowTech in Louisiana and he will take care of you. The cost for a total rebuild of the block, WUR and injectors is about $800+_ alum or iron.
Fronkensteen
Old 05-28-2014, 12:06 PM
AirtekHVAC
AirtekHVAC's Avatar
Paul....to me, the rebuild seemed easy (cast one)... But I have torn it down 4 times now, and my car still does not run....
If you have not done it before, be meticulous, and watch out for the little washers.
Old 05-28-2014, 02:56 PM
Fronkenstein
Default Why am I doing this? Rebuilding a fuel distributor
Originally Posted by AirtekHVAC
Paul....I have torn it down 4 times now, and my car still does not run....
I have been rebuilding all sorts of intricate mechanical devices for most of my breathing days and as simple as this distributor _seems_, it really needs some specially tools that most of us, even tool junkies, are not going to invest in. Most of it jigs and things specific to the unit in question.
Just the lapped surfaces alone require a great deal of care and attention. Using the wrong materials will cause you issue as well. And finally there is just the experience factor that comes from having done it _right_ many times.
I'd say that if you have taken the time to re-do your work four times and still have not met with success, you have more than overspent on your CIS system. Send it to a pro and get it done and have fun running the car. As I said I spent $800 for 16 injectors to be ultrasonic cleaned and flow tested; rebuild my WUR and rebuild my fuel distributor. I don't know about you but my time professionally is worth $200 / hour. So I figure I saved $800
Fronkensteen
Old 05-28-2014, 03:01 PM
Fronkenstein
Oh yeah, forgot to mention. The 928 fuel distributor flows more stock than the MB Bosch 0.438.100.111 version. And there is no physical modification that needs to be made to the block to crank it up. What I mean is there is no machine work necessary to the flow slits. You can change the characteristics by changing the output nipples and fuel return and other non-invasive tweaks.
I just acquired a euro 0.438.100.111 that I am going to have rebuilt and play around with on my M28.22 and see what I can squeeze out of her. I will post results at some point over the summer.
Fronkensteen
Quick Reply: CIS feul distributor
