Hvac lamp
Hvac lamp
Hi,
Quick question, what is wattage of the lamp behind the Hvac panel?
Is it a 12v 1,2w lamp like the ones on the dashboard?
Maybe I’m not looking as I should but I cant find it in the Pet!
TIA
Regards
TIA
Regards
BTW, don't succumb to the temptation to replace that bulb or others in the warning panel (door lock/central warning) with an LED/Resistor combination.
I did that, with the thought that the LED would last forever and would provide a nice whiter light.
What did happen was that the lights never go entirely off and the AC light behaves unpredictably. Of course, I only tested for basic function before re-assembly, so the odd behavior was not noticed till that night after everything was reassembled.
I suspect it is related to the different impedance of the LED/Resistor combination, but have not had the time to remove that panel again for further testing so that is only a guess.....
So, I have pointed out the wrong way to do it, and Joe has pointed out the right way...
Balance has been restored to the 928 Universe......
Joe,
I based my replacements on the LED's I saw on e-bay that were for 12v.
All seem to be LEDs with resistors soldered in line ( which is what I did).
Example here:
http://cgi.ebay.com/15p-3mm-pre-wire...item2c528527ba
What source did you use for true 12v LED's?
My original reasons for using LED's are still valid, long bulb life and nice light, so if I have to pull the console apart and replace them, I'd like to do it the right way...
-Ken
Example here:
-Ken
Hi,
Thanks for your opinions and advices.
I was just thinking of replacing the Hvac 12v1,2w bulb with a 12V direct replacement Led, trying to have a more bright light in the controls.
Also to replace the pod buttons bulbs.
This is the replacement bulb I ordered, they say it’s a direct replacement. Do you think it will work just “plug and play”?
http://www.autobulbsdirect.co.uk/286...bs-286LED.html
TIA
Regards
TIA
Regards
Hi, can anyone point a thread or give here an instructions how to replace broken bulb in HVAC-unit? I have 12v on connector pin 3 in a car side and I also checked that lamp didn't came on by giving power from external battery to pins 3 and 4.
So bulb is broken but how can I replace it? I assume that red wire is ending to the bulb but that about all.
Thanks for any advice
-mikko
-mikko
A quick "search" of this fourm using the words "hvac bulb replacement" displayed several threads many with pic's
https://rennlist.com/forums/928-foru...lb+replacement
Just trying to teach you to fish
I did mine w/LED's last winter, I would not go back to the stock look (but then I've owned the car for over 12 years and wanted to update it
