For you guys that have replaces lower ball joints...
when you replaces the crap aluminum ball joints with the steel ones, did you keep the old style mounts and just trim off the extra length? i need to do the lower joints and im trying to save a few bucks.
jake
jake
i know in the WSM it says that the shock mount will be diffrent and can cause it to hit the A-arm. but im going to use the 928ms koni-hypercoil kit any way.... so that should not matter.
thanks guys
thanks guys
Rennlist Site Sponsor
Three ways to go:
- Buy new brackets.
- Install the old brackets and cut off the extra length.
- Install the old brackets and don't worry about it.
But - If you still have the old aluminum lower ball joint carriers, you DO need to install new steel versions ASAP! It isn't much fun to have a front wheel fold up into the fender...
- Buy new brackets.
Just had this done on my '78 - do as soon as you can. I bought the new ball joints from one of our established vendors, and only 2 new concentrics. You don't need to buy all 4 concentrics (this is a big $$$ savings - they are expensive) or the brackets. Also, don't worry about the extra lentgh on the bolts - won't hurt anything. You can DIY the job - do a search - Dwayne has an excellent write up on this.
