928 Forum 1978-1995
Sponsored by: 928 Specialists
Help with motor mount
Old Dec 29, 2009 | 11:21 PM
jeff spahn's Avatar
jeff spahn
Default Help with motor mount
Hi-
I have been searching and searching the forum for a post that took me to a link for porsche motor mounts that I saw for $178 each for the 1990 928's version of the mount. I know I saw it when I did research on replacing my mounts.
Anyone know of which supplier had the non-Ford motor mounts for this price. I have been pulling my hair out trying to find it. If not, where is the best place to get the best mount for my 90 928?
Figured I'd exhaust the search function before I asked.
Old Dec 29, 2009 | 11:23 PM
namasgt's Avatar
namasgt
Whats wrong with the Ford ones?
Roger, 928sRUS sells the Ford ones. Go on his web page and call him up. he might still answer.
Old Dec 29, 2009 | 11:32 PM
Stromius's Avatar
Stromius
I got a set from Roger along with silicone oil pan gasket and new pan studs/nuts. Have a read of this thread: https://rennlist.com/forums/928-foru...t=motor+mounts
Old Dec 29, 2009 | 11:34 PM
docmirror's Avatar
docmirror
Shameful Thread Killer
Unless you are going for concours, you want the Ford mount from Roger. If you demand, he will gladly sell you genuine Porsche MM. They will not be $178 each.
Old Dec 29, 2009 | 11:52 PM
Stromius's Avatar
Stromius
(instead of $35-40/each )
Old Dec 29, 2009 | 11:56 PM
the flyin' scotsman's Avatar
the flyin' scotsman
There's 3 mounts to chose from that I know of:
1) Porsche.......soft MMs......mega $$$ and will fail
2) Ford............soft MMs......less $$ but will fail
3) Ford ...........hard MMs......less likely to fail but may cause other rubber failures.
928 at last's Avatar
928 at last
Default There's always a reason.....
Originally Posted by jeff spahn
Hi-
Hey Jeffrey,
Put the ones from Roger in my car this past summer. ('90 S4) No issues and they work fine. (Will also last a while longer I'm willing to bet). A word to the wise, do the trans mounts while you're at it for full effect. (Thise are only available from Porsche and ain't cheap) but as usual, Mr. Tyson can provide at reasonable pricing. There aren't any links on here that I'm aware of that lead to $178 motor mounts. If that were the case, we all might as well hang out at the dealer.
Old Dec 29, 2009 | 11:59 PM
928 at last
Default ???
Hi Malcolm,
Care to elaborate on the "other rubber failures"?
(Nothing worse than a failed rubber)
Old Dec 30, 2009 | 12:23 AM
ROG100's Avatar
ROG100
Basic Sponsor
Porsche MM's currently $270 each - Porsche has actually decreased the price recently.
I wonder why - over stock????
Old Dec 30, 2009 | 12:24 AM
ROG100's Avatar
ROG100
Basic Sponsor
Solid Rubber Motor Mounts $46.50 each with the correct hardware.
Old Dec 30, 2009 | 08:20 AM
jeff spahn's Avatar
jeff spahn
Okay so now I am confused. Go with the solid mounts or the delicious liquid center mounts from Roger? Also, the "other rubber failures" has me wondering, what other rubber parts? Only trans mount I saw for the 90's was the one that is around $75. AIt's 6:30 am and I am eating breakfast and haven't broken out the WSM on the trans mounts yet.
Old Dec 30, 2009 | 10:14 AM
SeanR's Avatar
SeanR
Go with the solid rubber ones from Roger. They are the ones all the cool kids on the playground use.
Old Dec 30, 2009 | 11:11 AM
Schocki's Avatar
Schocki
The MM's that Roger sells are solid rubber and the best bang for the buck.
The tranny mounts are solid rubber too, but have to be from Porsche. At least they don't cost an arm and a leg.
Old Dec 30, 2009 | 11:25 AM
davek9's Avatar
davek9
I have installed three sets of the solid rubber ones and they work great, do the pan gasket w/stud kit as it makes the job easer to do.
Most important get your hands on a Inch Lb Torque wrench, as 20 to 25 inch lbs is a bit hard to feel and you don't want to over torque the gasket, it will split, it will leak, and you will be doing it all over again.
Old Dec 30, 2009 | 12:08 PM
the flyin' scotsman
Originally Posted by 928 at last
Hi Malcolm,
True that Rob
I added the 'other rubber failures' as a caution to double check fuel and coolant connections. Fully collapsed MMs cause the engine to drop and rest on the x member. The new MMs allow the engine to 'rock' which may cause an older hose to fail.
