Injectors not firing / No Start
#31
Thanks! ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
or pin 13 from the ezk that is basically what you are saying, pin 1 on LH?
so, where does that pin 1 or pin 13 from the EZK end up on the fuse/relay panel?
Thanks,
Mark
and here is the EZK that i wanted to post before.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Thanks,
Mark
Hi Mark, you are always the exception to the general rule :-)
In your case, the problem will be the link from pin 1 LH on fuse/relay panel to the tach in the dash, or no power to the tach....... etc.
If you look at the circuit of the fuse/relay panel for your MY car then you should be able to identify which connector/pin at the bottom of the panel carries that rpm signal to your dash pod.
#32
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
I discovered that through the troubleshooting process someone had replaced the CE from guess what....an automatic car. Removed the relay and it runs.
Initial efforts were correct however, the CPS that was in the car was in fact bad. Shame the previous troubleshooters didn't try that.
Again, thanks to all for the input.
I intend to keep this thread open to complete the PC based o-scope.
#33
Excellent ! Have seen that one a few times before :-)
Mark, yes pin 1 LH is fed from pin 13 EZK with a spur off to the tach. What MY is your fuse/relay panel ?
#34
Good news! Glad you resolved the issues.
Thanks John! MY is 1988. the pod is almost removed functional, but loose, so I can see all the connections on the middle main ribbon connector. (which i think goes to the tach)
#35
You can use your multimeter on ac volts to trace the signal if you can run the engine. Otherwise Ohm the wire out out, or use a buzzer .
#36
this thread is awesome! thanks
Ok, get this
the drawing of the relays is wrong. the kickdown relay is XV, not XVII which is the AbS. the bottom connector of the relay (I forgot the pin number, i think 31b) goes to that blue wire at the bottom of the W connector on the fuse panel. on the holbert car, this was cut. off the harness, the blue wire, was jumpered to the green wire on the J connector
(J11). (which also seems to connect to the kickdown relay bottom pin). My thoughts are that my wiring harness blue wire, leading to /or from the W connector (W11) is cut. that could be the issue! I thought because they led to the kickdown relay XV, that it wasnt needed due to it being a 5 speed. Ill re-jumper it like I had on the Holbert car and see if the tach comes alive.
You mean, W11, not W1 below, right? I see how this is all working. I bet that is my issue. too bad i cant start it right now, as I have all the radiator and oil out of the car!
edit: I think on the holbert car, J11 was cut, and the wire that normally leads to W11, was connected (jumpered) there. could it be that the M11 provides the speed output signal as that drawing refers to ? if not, is that yet another speed signal output that leads to somewhere else?
Ok, get this
Tach signal from LH1/EZK 13 comes into fuse/relay panel on W1 and goes out to the tach on J11. To find those pins, see diagram in post #9 in this thread. The wire then goes from J11 to pin 2 of conenctor "B" on your dash (assuming that is also MY 88). It is a green wire. Hope that helps !
#37
Isnt the unused relay, relay XV, NOT XVII??
other than that, this helped me find my issue I think.
Thanks,
Mark
Thanks,
Mark
This could help, someone had it posted in another thread, it is for a '91.
This is an excerpt of Porsche 928 Electrics - Wiring Diagram Primer ©Copyright Alan C. Moore 2006, 2007
See www.928-Electrics.com for further information, updates and other services - including the full Wiring Diagram Primer document this is excerpted from and details of the master document Porsche 928-Electrics of which the Wiring Diagram Primer is one section.
#38
john! I just checked the continuity between W11, J11 and both go to the green wire on spot 2 on the tack connector at the dash! whoo hoo! but, like I said, the blue wire that goes from the engine wiring harness for W connnector is cut. so, ill jumper it or hey, maybe even replace the connector to the W connector at W11. either way, i think that is the issue. thanks !
mark
mark
#39
Voltage divider: Want to say I am not the first to post how to make a divider but I think this is the first basic drawing that most should be able to make.
OK I did this in paint let's see how it goes.
Disclamer: I am not responsible if you fry your Notebook, however this has worked for me and Andrew O.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
working Demo
http://www.youtube.com/results?searc...rch_type=&aq=f
working Demo
#42
Let me know if you need more info on how to make the Divider.
DaveK9
#43
Davek9,
Thanks for the sketch for the Voltage Divider.
All I have to do is buy the parts and make one as well as install the programme on my netbook.
Thanks again,
Tails 1990 928S4 Auto
Thanks again,
#44
That's cool, please keep in mind that most head-phone jacks (male and Female) are three wire, and so is the head-phone cable.
My drawing only denotes using two of the three wires (Left or Right and the shield for ground).
If one were to build two Voltage Divider's in the box, and have two probe inputs, you could use both the Left and Right Audio inputs into the Notebook/PC and have a dual trace scope![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Please post your results, I think I'll do a new thread as John Speake has suggested and place a link it to the one that I learned from.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
#45
In a '91, it's relay location XVII. In an '88 it's relay location XV.
The plug locations at the bottom of the fuse panel for the signal going to the tach are also different between the '91 and '88. On the '91 it's M11, as pictured in the diagram, and on the '88 it's J11.
The two channel version is handy for comparing two different signals and how they relate to each other. S4 tach and cam position sensor signals:
