Lots of Lifter Noise this Winter; use an additive while storing outside??
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
It's rich at idle, but not black smoke rich. Of course I'm going to change the oil as well as the 2 dampers before taking it out again. It's going into hybernation tonight till I get my parts together.
Fuse 24 Assassin
Fuse 24 Assassin
I've decided to yank the battery and let it sit under a cover till I fix it. A nice fresh oil change and new dampers before smog time in 2 months ought to put it back on the road free of rich-idle problems.
Let the withdrawls begin until then.
Reanimator
Lurking from the 951 forum as I too have noisy lifters and am seeking all info I can get. Looks like a good drive is the first thing. Any way, on to the mice/rats. I have found that Bounce fabric softener sheets seem to keep the little destructors at bay, at least the mice. We don't have too many rats where I'm at.
Harvey
Harvey
I used to have noisey lifters on my 87 s4. It progressivly got worse, particualrly if the car sat for a few weeks.
I assumed the little springs inside my hydraulic lifters were shot (had this happen on a volvo), so I bought 32 used lifters, (not cheap) and just before taking the cams out a time saving miracle occured. Marc anderson mentioned something to me in a routine phone call.
"S4s with the short cams have a rubber plug that blocks two oil circulation holes that are no longer needed. The plugs go bad and literally fall out."
I checked noisy head and what do you know, one had fallen out and the other was badly warped with age.
His solution is small metal rods that block the passages with something that wont age or warp.
I have not had lifter noise since. Thats in 4 years, 27,000 miles of use!
-Sam
87 s4 5 spd
78 euro 5 spd
-Sam
87 s4 5 spd
78 euro 5 spd
Hi
Do you know the part numbers for those rubber plugs ?
Or alternatively where did you get those "small metal rods" ?
Bernhard
http://www.928.dk/gallery
Porsche 928 '87 Slantnose,
X-Over,Cats,Rmb,Smt6
Bernhard
-Sam
87 s4 5 spd
78 euro 5 spd
-Sam
87 s4 5 spd
78 euro 5 spd
I run 5w40 in the 928 and a Miata . Have never had a noisy lifter in either since the switch, and elderly Miata are prone to noisy lifters on the stock oil spec. Once it started so noisily SWMBO shut it down and called me to see if it was safe to drive.
Mind you we dont get much lower than 50F here.
jp 83 Euro S AT 52k
jp 83 Euro S AT 52k
Bernhard,
I have not had lifter noise since. Thats in 4 years, 27,000 miles of use!"
The part numbers for the rods are 928.105.262.00. There are 2 in one head and 3 in the other, so order 5 for a car. They are $1.23 each in the US, so it won't break the bank. Yes, one dollar and 23 cents. That must be a record for a Porsche 928 part, but Porsche was fixing their screw up.
I have installed these in several '87s. The symptoms were, very low oil pressure at idle along with a lot of lifter ticking. As soon as you revved it above ~1200, the engine quieted down and sounded normal, but let it idle and immediate lifter noise. For some reason it was always the right head. The original plugs had the consistancy of playdough. You can mold them with your fingers.
Thanks for the #'s
Are these the ones :![](http://www.mailordercentral.com/928intl/images/92810526200.jpg)
Although my lifters on the right side tick, my oil pressure is 3 bar(idle) when hot .
I'll change the oil plugs as soon as i have some new.
$1.23 is record for a 928 part, but then i'l need new cam cover gasket's and other wyait item's.
Bernhard
Bernhard
