heater valve
#31
usually a problem that all of a sudden starts happening requires the question......
what was the last thing I fixed.
I hope that you find a loose harness connection or a vacuum line that might have gotten pulled out when you refit the console, a visual inspection usually will be enough to find the problem
I'll be removing the pad, dash, console this weekend and maybe I can find the unplugged connection or vaccum line, or God knows what else. Hopefully that's the only thing I'll find.
![nono](https://rennlist.com/forums/graemlins/nono.gif)
The good news for me is that I won't have to drive to Detroit and back without heat. That would be "unpleasant".
Thanks for the help so far guys, I couldn't own these without you all.
Rod
#32
I don't know what was fixed recently, other than I pulled the radio to fix a destroyed control panel and found the extra wiring. I suspect that when they installed the radio, there could have been other things unplugged...
I'll be removing the pad, dash, console this weekend and maybe I can find the unplugged connection or vaccum line, or God knows what else. Hopefully that's the only thing I'll find.![nono](https://rennlist.com/forums/graemlins/nono.gif)
Rod
Rod
You've got this waiting for you when you arrive here in Detroit.
![](http://www.classic9leathershop.com/linendash92801.jpg)
#33
Wow, that's beautiful. I think it will look great with the Venitian Blue outside. I don't know if I'm ever clean enough to ride in a car with that interior, but I'll try. :-)
Can't wait. The pod will really make it!!
Rod
Rod
