heater valve
A dumb question, Is the heater valve behind the engine OPEN when the heat is on or CLOSED. Mine is currently open - water can pass through - but I'm not getting heat??? It makes sense that it would be open to allow hot water in, BUT the default - without vaccum - is open which makes me wonder.
Thanks,
Rod
Thanks,
Rod
It should be open with the heat on and yes it defaults open.
The HVAC system supplies vacuum to close the water valve. If you've no heat hows the other parts of the coolant system?
Rod
MIGHT not apply to these cars but on my Mercedes I had to BLEED the air out of the system to get heat. Then it was working fine. I just took the hose loose on the return side of the core and let it drip, DID NOT remove the hose just got it to leak then tightened the clamp back.
I looked in the manual and it said nothing about bleeding the system so take the hint for what it is worth.
Team Owner
928 is a self bleeding system no need for any special procedures . Note the hose on the top of the radiator and the top of the water bridge.
To fill the system simply remove the cap let the car warm up make sure the bottle has atleast half full , put on the cap, then drive the car for about 5 miles then park it and let ot cool off top up as necessary
Could be bad engine thermostat. When they fail they default to a full cool position and your engine/heater water never gets very warm. Check water temp gauge.
Rod
Team Owner
how old is the heater valve, if over 5 yo then replace it along with the short hose.
Have you verified its open while the car is running?
What are the temps at the top rad hose compared to the heater hoses use your IR gun to find out
Have you checked the coolant return hose? If its cool also then the hot coolant is being restricted from entering/leaving the system but thats assuming the coolant is getting hot enough.
Checking the t.stat is a good suggestion.
Rod
Too old school Jim
I'd go out and grab a little snow then where it doesn't hiss very loud that where the engines coolest.
Back in the my m/cycle days we'd spit on each exhaust pipe to id which cyl was cool and trouble shoot from there............burnt my finger tips a few times
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Basic Sponsor
Rod,
Are you sure your recirc flap is not open to outside ambient air.
If it is - it defaults to open when the diaphragm fails - this allows lots of cold air in to negate the heat from the heat exchanger.
Roger
Roger
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
I did check the hose temperatures and they were low, about the same on both hoses, only about 5-10 degrees difference, so I am picking up a thermostat to put in today. If that's not it, it will be "preventive maintenance".
Rod
