928 Forum 1978-1995
Sponsored by: 928 Specialists
The S4 brake conversion thread (tech with pics)
Old Jan 3, 2010 | 11:29 AM
toofast928's Avatar
toofast928
When that rotor heats up do you think it's going to rub?
Old Jan 3, 2010 | 12:00 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
im in the process of doing this same style upgrade to my brakes. and when i jacked up the car the POS aluminum ball joint popped out on the driver side.... so they are indeed trash.
Old Jan 3, 2010 | 03:23 PM
chewy8000's Avatar
chewy8000
They are aluminum bits so I need to replace them. Do I need the ball joints and all the eccentrics as well?
Old Jan 3, 2010 | 03:48 PM
Ducman82's Avatar
Ducman82
Veteran: Air Force
you need the steel joints, 2 more eccentrics (you can keep two of the ones you have now) and eather use the same shock/ball joint bracket, or get the newer updated ones. i got the newer ones so the "complete" update is done. but that was another 160 i did not want to spend.... ah well.
