Project this weekend: S4 brakes checklist for the 81'
Here are the parts I have assembled just want to make sure I have everything and it's the right stuff to get the job done:
(2) front 993 cross-drilled rotors
(2) rear S4 rotors
(4) S4 calipers
Front S4 brake pads
Rear S4 brake pads
caliper adapters
5mm washers for spacing the rear calipers
Stainless goodridge brake lines
Racing blue brake fluid
Motive power bleeder
(2) rear S4 rotors
(4) S4 calipers
Front S4 brake pads
Rear S4 brake pads
caliper adapters
Anti squeek pads or paste
Are the calipers in good order - otherwise new seals and/or bleeding nipples.
Copper crush washers for the front brake lines
Copper paste on the sides of the brake pads and caliper bolts
Aluminum paste for the caliper springs
Basic Sponsor
Beer???
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
I thought you needed 78/79 spindles to do the conversion.
On mine, I only needed about 2mm spacers on the rear.
Also you might consider getting a quart or two of generic DOT3 brake fluid; use that to start with, bleed the brakes, go bed the brakes in, drive it some, bleed until you're sure there are no air bubbles, THEN fill the system with the more expensive blue stuff.
The anti-squeak pads are optional, but something you may want to consider.
If your current setup has the front caliper mounting bolts threading into nuts welded to the backing plate you may want to get shorter bolts - I don't recall the exact length but they were a lot shorter.
Man of many SIGs
You have most of the parts. You will need the S4 caliper bolts and washers for the front.
Do the front S4 calipers bolt to the 81 spindles.? If they bolt on you will need spacers and longer caliper bolts. If they are not a direct bolt on you will need adapters.
I have the caliper bolts and the caliper adapters I'm pretty sure you don't need to swap the spindles. Looks like all i need is beer! I'm also doing the bilsteins and eibach springs this weekend. Got the "while I'm in there" bug.
chewy
chewy
You going to put on Dust Shields? If so, you need to do new ones that will clear the new rotors. S4's.
Wheel bearings, grease, etc. If you get new front rotors, they do not come with bearings.
(if I recall correctly)
Rest in Peace
You will have to cut holes in the dust shields at the tie-rod end!
You better check that you have at least 1/8 inch space between rotor and tie-rod.
You better have at least 3mm spacers for the front wheels and check your offsets!
How do I know this ... I did this already to my '81
Rest in Peace
If bearings are good, you can just reuse.
When you replace dust shields, you have to remove the front hub assembly which contains the bearings, etc to get them off. Since bearings were original, I went ahead and replaced and repacked them.
I did S4 dust shields in the front.
Rears are much easier upgrade.
