928 Forum 1978-1995
Sponsored by: 928 Specialists
Idle problems @ operating temperature in Closed Loop - Need to borrow '88+ LH/EZK
Old 12-09-2009, 03:17 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,773 Likes on 1,347 Posts
Bill-
IIRC Andy's got '88 chips now? I think I sent the '87-'88 cable to you and Sean - If you're done with my Spanner, mail it to Andy and I'll pay the postage - it'd be worth the cost to see the diagnostics/exorcism done!
Old 12-09-2009, 03:25 PM
Bill51sdr
Fleet of Foot
Bill51sdr's Avatar
Originally Posted by Rob Edwards
Bill-
Hi Rob,
Yeah, I'm about done with it, told Andy I have it and to contact you about borrowing it. Thanks for chiming in! Don't worry about the postage on my end, I'll take care of it (thanks for the use of the tool! ).
Ball's in your court Andy. Do you want to find out what is REALLY wrong?
Old 12-09-2009, 03:43 PM
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
Heck yes, but I don't have '88 chips. I can throw the tool on it and see if it still works with this new LH still. I will reimburse you for the postage also.
Time to put an end to this stupid charade.
Old 12-09-2009, 04:01 PM
Rob Edwards
Archive Gatekeeper
Won't work with '87 chips.
Old 12-09-2009, 04:08 PM
Mongo
Fuse 24 Assassin
Mongo's Avatar
Then if anyone in the Bay Area is reading this with an '88 or newer LH/EZK they have lying around, may I borrow it please for diagnostics?
I am hating the '87 year more and more regardless if the thing has piston squirters etc.
Old 12-09-2009, 06:12 PM
fraggle
fraggle's Avatar
Check your new o2 sensor connections. If you used that ****ty universal connector that came with the sensor, dump it and get some real crimps.
I did this after having the exact same problem - stalls at idle at op temp - and it completely fixed it.
Old 12-10-2009, 01:58 AM
RED SHARK 1990
RED SHARK 1990's Avatar
Default o2 sensor
Check with BLYTHE ,i gave him an extra orig BOSCH o2 sensor made for the r my car 90s4 1year old. If he still have it you should asked him.....He sold his s4 so therefore should be no need to him...
Old 12-10-2009, 03:48 AM
Lizard928
Lizard928's Avatar
This is why I asked the question on pg 1 if it was a universal or factory part.
Old 12-10-2009, 01:18 PM
Mongo
Fuse 24 Assassin
Mongo's Avatar
It's universal (per what I posted on Reutterwerk to you). I did the usually warm up in the cold weather last night until it got up to operating temperature and started running rough again. Got out, disconnected the Temp II sensor and restarted it. The sucker ran like it just stepped out of the showroom - idle was smooth as glass! Reconnected Temp II again, restarted and it ran like ****.
Quick Reply: Idle problems @ operating temperature in Closed Loop - Need to borrow '88+ LH/EZK
