928 Forum 1978-1995
Sponsored by: 928 Specialists
Cheapest double fan upgrade ever
Old Dec 1, 2009 | 11:42 AM
Imo000's Avatar
Imo000
Captain Obvious
Super User
The Contour/Mystique rads are a lot thinner than the 928. About half the thinckness. They are designed for a 2.5L engine.
Old Dec 1, 2009 | 12:19 PM
Lizard928's Avatar
Lizard928
The only thing that I would like to add to this discussion is that those of you in really really warm climates and 32V engines might not get enough jam from this setup.
As well, dont forget to cut up the factory shroud to have the attachment for the intake tubes, and to seal off and force more air through the radiator.
Other than that it looks sharp.
Old Dec 1, 2009 | 12:38 PM
DR's Avatar
DR
Rennlist Sponsor
Colin,
Good point!
We have an upper trim for our fans but it also works for other aftermarket fans.
All you do is remove the air funnels and rubber trim from the old fan shroud and install them on the upper trim.
Also has a cool 928 logo :-)
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
Old Dec 1, 2009 | 01:53 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Here's what the Contour/mystique fans look like and the dimensions for it. I'll double check the pics when I get home but I'm pretty sure these are the same ones I have on my PC.
File Type: jpg
File Type: jpg
Old Dec 1, 2009 | 02:18 PM
andy-gts's Avatar
andy-gts
great work....I can't wait to find one in the junk yard....but even new it would be a steal!
andy
Old Dec 1, 2009 | 03:41 PM
G Man's Avatar
G Man
Very cool! I like the RD as well. I used to have a couple of Kawasaki triple two strokes. Fun as hell in a straight line but lousy in the corners.
Old Dec 1, 2009 | 04:04 PM
karl ruiter's Avatar
karl ruiter
$139 new at monsterautoparts.com.
Old Dec 1, 2009 | 04:28 PM
Maybach_Man's Avatar
Maybach_Man
is the cfm o.k??
Old Dec 1, 2009 | 05:04 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
If you think the RD/RZ350 were good, you should try the big one, the RZ500. I used to have one and it was a giant killer.
Old Dec 1, 2009 | 05:19 PM
danglerb's Avatar
danglerb
Use caution, that one, like many others are NOT OEM fans, they are cheap copies made to look and fit the OEM. Sure bet they don't use the same grade Siemens motor etc.
Best price I found for the Motorcraft fan was http://www.silverstatefordparts.com where its about $240 new. Used stuff on ebay seemed in the same price range as the Mark8 fan, about $75, but my guess is this is an easy find in the local Pick a Part.
This isn't going to flow as much as the Mark8, or even the Taurus fans, but for the supercharger guys it has more middle of the radiator clearance since the motors are smaller and offset to the sides.
Our radiators are cross flow, hot on the intake side, cooler on the outlet side, not a big difference if they aren't clogged top to bottom, so given a choice put the fan on the hot side.
Don't hook up an OEM fan to any switch, use a relay at least rated double the current, like a 75 amp Bosch.
Old Dec 2, 2009 | 10:44 AM
Bart-Jan's Avatar
Bart-Jan
I would say: why buy it new, when it can be bought as good as new for only a fraction of the price.
The drawings look very much like the fan shroud I used. I made some new pictures of the bottom end of the rad and fan. There's also a better view of the RD/RZ350 on the background and also part of a kitcar standing on its side - another project waiting for excessive amounts of time...
Attachment 403033
Attachment 403034
Old Dec 2, 2009 | 11:29 AM
terry gt's Avatar
terry gt
nice fan setup, how do you mount it ? Terry
Old Dec 2, 2009 | 12:24 PM
Bart-Jan's Avatar
Bart-Jan
On the second picture on the first page, you can see one plastic hook, that is shaped around the middle of the top of the radiator with help of a dremel. On the top right of the picture, next to the connection of the upper hose, there used to be a fixation point for the Ford. That needed to be cut away. Lower down on that side is another one that with a seperate brackt is hooked behind the hook on the Porsche rad (invisible on the picture).
On the left side of the picture, you can just see an aluminimum bar that crosses from the upper to the lower fixation of the fan shroud and that hooks behind the other side of the Porsche rad.
It feels quite secure, but while reviewing my own pictures, I noticed I can add some brackets at the bottom. I will do that just to be sure.
For now, I will switch both fans on and of at the same time and remove my front mounted fan.
Thanks for all your comments and help!
Old Dec 2, 2009 | 01:31 PM
76FJ55's Avatar
76FJ55
Is that a square tube chassis I see in the second to last pic you posted? it's hard to tell but it looks remanisint of the FSAE cars I was involved with in school.
Old Dec 2, 2009 | 05:12 PM
sharknoob's Avatar
sharknoob
this would be another option I picked up one of these last year but have not used it yet
http://www.summitracing.com/parts/FLX-31165/
