Will 993TT calipers & rotors fit S4 with 17" rims?
Hi,
looking at a set of front rotors (322mm) and calipers from a 993 tt. What would I have to do for these to fit the front of my S4? The rotors are drilled and 27.5mm thick so slightly thinner than std S4 rotors.
Would this be a worthwhile upgrade over the stock brakes (street use)?
Cheers,
Myles
Cheers,
Myles
Ask roger, I think the ones I bought from roger for the gts were 993tt and were a fit but there was some machining needed that roger had done before the sale.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Hi,
Cheers,
Myles
Cheers,
Myles
993TT/928GTS calipers and discs are a great upgrade...
Thanks for the replies.
So the rotors are no good as a bolt on but the calipers would work with GTS rotors as a bolt on.
Is this correct?
Cheers
Myles
Is this correct?
Cheers
Myles
Correct. The rotors would bolt on to 78 spindles for someone doing that conversion, but they are not properly huub-centered; you would need to use the flathead screws to hold the rotors centered for assembly and double-check runout before putting it together.
