Best way to get switched and non switched power?
Rest in Peace
Where is the best place to pick up power, both switched and non switched?
I will not cut into a wire or use Scotchlok's.
Can I install a extra relay?
Also where is the best place to install a couple of small electronic boxes?
I need to install a 5 volt transformer for a Sirrus radio, a control box for a Escort 9500CI and the speaker for it.
Received 1,603 Likes
Add-a-circuit is definitely quick, easy, and reversible. Plus, you get a fused circuit.
If the factory amp has been bypassed, then removal provides a bit of space for small boxes. And, IIRC, there's switched and unswitched power at the booster's harness plug.
