Nicole/Jager LED Instrument Pod Illumination Question
Do LEDs burn out?
I installed the Jager/Nicole LED kit into my instrument pod (86.5) and the right LED started flickering, then went out, followed by the left, followed by the center. Is there such a thing, or do I have a bad connection in there?
Just pulled the instrument pod and tested each LED by hand with a 12 volt power supply-- each of them are dead.
Did I get unlucky with a bad batch of LEDs, or is there something happening in my electrical system to burn out LEDs?
I don't know what voltage at the sockets because i had to pull out the instrument pod to get at the LEDs. However, when I feed 12 volts through pin 16 and 17 (ground) I get 12 volts at the sockets, so there's nothing weird happening there.
Check voltage on the car side of the pod connector to be sure.... Sounds like they failed....Nicole/jäger are great at customer service shoot em a line or call, they will take care of you.
Dissected the LED, which had a 270 ohm resistor soldered in. (The resistor was hidden by white tape which I cut out.)
I don't know what the LED current is of the Jager illumination kit but most LEDs are 2 mA, 10 mA and 20 mA. If that is so, the resistor necessary would be between 500-5600 ohms.
In other words, if the LED current is between 2 and 20 mA, then the wrong resistor was installed into the kit, which resulted in the LEDs blowing out. I am going to the store right now to buy replacement LEDs and resistors to see if this solves the problem.
