928 Forum 1978-1995
Sponsored by: 928 Specialists
81 928 not starting...
Old 11-03-2009, 09:52 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,546 Likes on 1,429 Posts
get a fuse relay chart here 928gt.com then go through all of the fuses make sure they are all good, clean them with a pink eraser.
Dont remove the injectors , just have someone go to the back of the car and listen for the pump to run while you crank it, no pump no run.
For a quick test to see if it is a fuel probl;em spray some ether into the intake about 2 seconds and then crank it if it runs for a second then you have a fuel delivery problem, just throwing parts at the car isnt the way to figure this out.. First check the fuses
Old 11-03-2009, 05:27 PM
MG928
MG928's Avatar
hey guys got it running!!! i checked what you guys recommended and it ended up being the injectors. i pulled them all out and several were all gummed up and werent firing. i cleaned them up and ended up getting them working. I popped em back in and it fired right up.
Mrmerlin i agree with you on not just throwing parts in. the reason i put all the new parts in was because when i bought the car it was missing of those parts!! yea i got a good deal on her..
thanks again guys for all the help.
Old 11-03-2009, 10:35 PM
6mil928
6mil928's Avatar
Location: No where Oklahoma AKA "The Dust Bowl" In The Arm pit Of Hell
Wow now that's clogged bad. How did it ever get that clogged?
Old 11-04-2009, 09:15 PM
MG928
MG928's Avatar
the car had been sitting for a while outside. thats why i ended up with the car it was going to waste and its previous owner didnt want that to happen. yea i couldnt believe it i wish i would have taken pictures of them to show you guys.
Old 11-04-2009, 10:21 PM
6mil928
6mil928's Avatar
Just because a car sits out side that doesn't normally lead to clogged injectors. Now the neglect is another story.
Quick Reply: 81 928 not starting...
