Belly Pan information Needed
Archive Gatekeeper
I'm going to have a perfect replica made from forged aluminum, and then have it anodized, to match my wheels.
Fleet of Foot
I guess I should have left all the grease on the underside to absorb the heat, and just cleaned the outside to reflect? Note bent lip. No front piece. One bracket, long V, is that right? Can I just get a front piece?
Archive Gatekeeper
Is the other 'V' still attached to the underside of the car? If not, you're missing one.
If need be you can make a new bracket out of a piece of flat Al stock from Home Depot after you put your car back together and test it without the pans... and arrive home without it. Not that it's ever happened to me.
