For Sale '88 S4 Guards on Black
The Good:
She is back together. The car will have a 4 wheel alignment before transfer of ownership.
![](http://gallery.rennlist.com/albums/album705/IMG_3194.sized.jpg)
Wheels and Tires:
New stock size tires, Fuzion ZRi's 225/50/16 front 245/45/16 rear installed/mounted 11/19/2009 on stock S4 wheels. The wheels are not real pretty but true.
Suspension:
New factory Boge/Sachs shocks mixed with stock original coil springs. (11/2009)
New 928 Specialists rear sway bar. (2009)
Replaced passenger side rear control arm, original was bent but allignable. (11/2009)
Replaced front suspension grease fittings and covers
Brakes:
Factory stock S4 Brembo's with relatively new pads and rotors.
ATE Super Blue (flushed fall of 2007)
Brand new emergency brake shoes/pads (11/09)
Engine:
All new fuel lines (2008)
All new vacuum lines (2008)
New throttle positioning switch (2008)
New O2 sensor (2007)
New Nology Ignition wires (2007)
New Bosch Coils x2 (2007)
New Temp II Sensor (2008)
New Bosch Knock Sensors (2008)
Rebuilt LH - www.jdsporsche.com (2008)
Intake Manifold and Valve Covers powder coated by Lomas Motorsports of Utah (2008)
New OEM cam chain tensioner pads (2008)
TB and WP replaced 2005 by previous owner. I have driven less than 10K miles since replaced.
New accessory belts (2007/8)
928 Specialists rear muffler bypass - RMB (2005)
New power steering lines (2005)
Bosch rebuilt alternator (2008)
Alternator breather hose (2008)
New Interstate 60month battery (2008)
New 928 Motorsports polished strut brace (have original)
New flappy actuator and bearings (2008)
Thrust bearing tension checked 11/09
New hood liner (2007)
New OEM hood struts (2006)
New Bosch copper sparc plugs (2007)
Fuel injectors cleaned and metered by www.witchhunter.com @ 18.5lbs PSI (2007)
Interior:
6 way power "Comfort" seats driver and passenger with 3way memory presets on driver seat
Front and rear AC
Momo shifter **** (have original leather "T" in good condition)
Porsche CR200 series cassette head unit with trunk mounted Porsche 6 disc CD changer. (2007)
MB Quart speakers all around (2007)
Custom speaker, sub and amp enclosure by Sound Solutions
“Superlamb” sheepskins - black (2007/8)
Lloyds "Ultimat" floor mats and rear deck cover (2008)
Replaced sunroof switch and sunroof gears serviced (2006)
Rear hatch/seat carpets re-dyed due to fading (2008)
Bray Krause Fire Extinguisher Mount (2007)
Halotron Fire Extinguisher (2007)
Exterior
New OEM lower air dam/spoiler (2008)
New Sigla front windshield (2005 non-antenna version)
Later model GT/S4 Fuba OEM roof mount powered antenna (2007)
New Philips headlamps bulbs (2007)
New OEM right front turn signal lens (2006)
New OEM Colgan 1 piece bra (2007)
New car cover (indoor use)
Engine service covers (2007)
The Bad:
AC (currently R12) needs service but has new/rebuilt dryer and condenser
Driver door alarm trigger is inoperative. Alarm can be armed from passenger door and from dash
Side view mirror controls are inoperative but work when using 3 way memory presets
No lock on gas cap
Missing wheel locks
ALL OTHER ELECTRONICS WORK AS DESIGNED
Remote hatch, windows, front and rear wipers, turn signals, hazard lights, sunroof, interior lights, door lamps, etc. all are in working order.
VIN - WP0JB0927JS861121
Option Codes:
CO2 - 018 - 158 - 418 - 494 - 533 - 533 - 570 - 650
Other
Info and a few questions answered:
PCA – Potomac Region Porsche Fest 2006, People’s Choice 3rd place.
Frenzy 10 - 2006 People’s Choice 1st Place for ‘87-’95 cars attending. <Wife was the judge, how could I loose?>
What is the mileage?
The actual mileage is unknown the speedometer stopped at +/-78K and gear was not replaced until 2009. Discussions with previous owner expressed an average of 4-5K per year since odometer quit. My best estimate is the body has 115K on it. Engine was replaced by Porsche @ +/- 59K for timing belt failure documented by Porsche dealership that completed the replacement.
What are the current/previous title issues, if any?
None other than a couple of failed emissions under my ownership leading to the intake re-fresh, new sensors and rebuilt LH. Car is current at this time and passed VA state emissions.
Where has the car been/locations?
Car was first sold at Don McGill in Houston TX, then moved to New Orleans and transported (documented) to Virginia just before Katrina. It’s been living with me since Jan 2006.
Has it been repainted / re-upholstered?
All but one quarter panel has been repainted at some time, always using single stage paints it's a 10ft, not a 2ft car. My guess is that the car was repainted at times due to minor mishaps and shopping cart encounters. The car has never crashed to my knowledge.
Is it original motor / transaxle?
No on motor and yes to transaxle.
Newer, more recent pictures will be posted over the next few days. For those of you that do not know the car. Here are some pics over the past few years under my ownership. The Cup I replica's are no longer on the car. There are now OEM S4 wheels on it.
![](http://gallery.rennlist.com/albums/album505/IMG_0008.sized.jpg)
![](http://gallery.rennlist.com/albums/album672/IMG_1144.sized.jpg)
![](http://gallery.rennlist.com/albums/album672/IMG_1146.sized.jpg)
![](http://gallery.rennlist.com/albums/album672/IMG_1149.sized.jpg)
![](http://gallery.rennlist.com/albums/album672/IMG_1157.sized.jpg)
![](http://gallery.rennlist.com/albums/album672/IMG_1160.sized.jpg)
![](http://gallery.rennlist.com/albums/album672/IMG_1172.sized.jpg)
![](http://gallery.rennlist.com/albums/album672/IMG_1197.sized.jpg)
![](http://gallery.rennlist.com/albums/album703/IMG_1400.sized.jpg)
![](http://gallery.rennlist.com/albums/album703/IMG_1403.sized.jpg)
![](http://gallery.rennlist.com/albums/album705/IMG_3211.sized.jpg)
![](http://gallery.rennlist.com/albums/album672/IMG_9547.sized.jpg)
Some of my paperwork. There is an inch of other stuff thought I would leave that alone.
![](http://gallery.rennlist.com/albums/album672/IMG_9553.sized.jpg)
(Make me a reasonable offer 9.5K is the starting point)
Michael
Wheels and Tires:
Suspension:
Brakes:
Engine:
Interior:
Front and rear AC
Exterior
The Bad:
No lock on gas cap
Missing wheel locks
Option Codes:
Other
Michael
Michael,
It is unclear in your post if the car is running or not at this point. Will make a HUGE difference in what you might expect to sell it for... Looks nice in your avatar for sure!
Very nice car, Michael. Wish I lived closer to you guys and could help you reassemble.
I've seen it, worked on it a little bit, and would love to bring it down here to Richmond. But alas, I would loose a lass in the process.
That's too bad you can't get it back together. It would really help your driving enjoyment, and you may not want to sell it.
IIRC, it's not rolling and it's up on stands. How do you plan to sell it this way? You're over halfway there to get the trans back in the and susp. carrier back up. And you would have to do half of that to at least make it a roller.
It is a nice car. Don't cut your losses.
It is back together.
It's just about done. No pic's until it is done. Shouldn't be more than a week, as to why I am bumping the thread. It is a very average '88 928 S4 with a lot of service recently completed and close to back on the road. Average car will bring an average selling price. NADA is listing 8-10K and I believe that I am closer to the top than the bottom. Please feel free to PM or IM me with your thoughts or concerns.
The transmission is now back in. As is most of the suspension.
It will go on ebay in the next week or so. Giving other rennlist members a chance to make an offer before I list it. There is not much room to play with the price but feel free to ask.
Michael
P.S. Let's keep the thread clean.
Good luck with sale. I assume once completed it'll drive anywhere?
That's a nice service history! I honestly would list it on autotrader for $8900 OBO with a service history like that. If anyone was to pay to have all the work done on that car you did, your looking at 10k easy from a local shop. Sounds like this car had a well cared for owner. Hopefully you have receipts for all the parts as well? I would put emphasis on the service history if you put it on eBay! Sounds like a good daily driver like my Cassirot!
My price is posted Gio.
Just trying to sort stuff out.
In the 5 years of being on Rennlist I don't think that anyone has posted a "For Sale" listing as detailed as mine.
I thought that maybe I could start a trend.
Michael
Michael
Bump..
Still on the market. Will post it on eHell and Auto Trader next weekend, that would be Feb 10th or so 2010.
Finished inspection today and good to go. What car doesn't have problems mine still has a few. I will continue to work thru them until either the 2001 VW GTI is sold or the 928 is sold. One of them needs to find a new home. Just not enough room for both.
New pics will be up next weekend for sure.
I will start a new thread to remove some negative comments. I wish that people used PM's a little more often. Sucks for thwe rest of us, others know the car.
