Comming back from the PCA races last night from Daytona.The car was acting scary. There were times where i thouhgt i was going to loose control of it.It was all over the road,strugging to keep it strait.The steering felt very loose.First thing i did this morning was check out the front end on both sides and every thing checked out ok.No loose screws wheels where nice and tight and i dont think that if the rack bushings are bad it would behave so extreme.Now things i done to it the week before.New rubber,new tie rods,new boots and a wheel alignment on hunter DSP600 machine at my local sears.WTF is going on here?What else do i need to check.A lot of advice is appreciated
I would have done the same thing and checked the lug nuts first. Sounds like maybe a bolt on the eccentric backed out; or maybe your tie rod lock down nut backed out. Essentially, your tire/car would track down every groove in the road. This web site has a quick reference to see if your alignment is out. If it is, I’d take it back to Sears. My $.02
I wonder if your "rag joint," an All-American parlance for an in-line coupler in the steering column, has died? The 928 has a rag coupler right next to the exhaust manifold.
<http://en.wikipedia.org/wiki/Rag_joint>http://en.wikipedia.org/wiki/Rag_joint
The symptoms you describe match those I've experienced with the two coupler failures I've experienced. Mine were progressive as the coupler tore more and more. That is, the looseness got worse over time, without failing catastrophically.
Jack the front of your car up, grab the tires at "3 and 9" and work it back and forth. Do it again grabbing at "12 and 6." Then find the loose component(s).
My '84 is doing the same sort of thing and if I ever get a job again will go to the shop for sorting... or if you guys will buy enough calendars and DVD's for me to cover the costs of the repair!
