Electronic Dash on pre- car?
928 Collector
Looks like the connectors on an 89 and ;ater instrument cluster are vastly different from the earlier S4's.... can they be retrofitted?
Electron Wrangler
H How much time do you have....
Anything is possible.. but there are some issues - you need the digital speedo relay and sender set up - most of the other sender etc remained the same - but there may be a few other minor detals - obviously you need to do a huge amount of harness grafting so you will need a pod harness from a later car to do the adaptation... A lot of work..
Alan
Alan
