928 Frame
The 928 has a unitized body, with no "frame" as such. The Factory workshop manual gives detailed measurements of the chassis, so Porsche expected it to be straightened and repaired.
It is usually possible to get all 4 wheels pointing the same direction. Possible to make it LOOK OK and sometimes it might even have the original strength. I tend to think it is like a cardboard tube from a roll of paper towels bend it once and it is predisposed to bend again. Porsche also sold replacement "frame " panels and complete body shells if needed to fix a crashed car. You need to really have faith in the bodyman and his abilities which may mean he is NOT the LOW bidder for fixing the car....
My car is stripped of everything basically pure metal the left fender and front bumper burned off, before I dispose of everything this car meant alot to me if at some time in the future I can fix it I won't throw it away now....Can it be fixed?
If 928 values will raise enough it comes financially feasable to fix almost anything. Already entire front ends have been swapped to save some. For example one ROW GTS had pretty bad accident and it received everything from windshield forward from S4. When done properly its virtually impossible to see what was changed. Problem is doing it properly costs more than most expensive GTS on the market today. Accident history cannot be erased and such car will always have substantially smaller resale value than fully original version.
Great starting point for a track car. Get it mostly true and the wheels all going the right direction and a simple cage will give you any additional strength needed. your just a motor and some seats and such away!
I'm not Jim, but a quick look in the price list I have with me shows the 928 "Body In White" part numbers range from $26,000 to $51,000.
Want me to try and order you one? :-)
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
