Dumb rear swaybar mount bracket question
Archive Gatekeeper
I would have said dumb newb question, but I'm not sure I qualify for newb anymore.
Anyhoo, how does this bracket come apart so it can come off the bar? Looks like I ought to be able to pry the little tab up and over the sandwiched halves, but that tab ain't so little, and I don't want to damage it. Thoughts?
Yes they do come apart and fairly easily. Had to do this when I installed 928 Spec. bars on my '91 GT.
Use a large flat-head screwdriver or small pry bar and place it horizontally across the mount in between the locking tab and the U-shaped bracket and lever toward the locking tab. This will unsnap the mount and you can then pry it open enough to remove the bushing and bracket.
Good luck!
Good luck!
Archive Gatekeeper
Edwards, in the garage, with the prybar. Got it, thanks!
Glad you got it.
Make sure you have the mounting bracket oriented in the proper direction for re-installation. Sorry I forgot to add this earlier. You may want to do one side at a time so you can use the original as a guide.
Supercharged
If it's not too late, you might want to lube up the bushings with a little grease. I didn't and now the go "squeaky squeaky." It's embarassing as hell, but the work required to lube them now is well out of the question.
This is why a pair of new greasable polyurethane bushings sit uninstalled on the shelf. Replacing the fronts - no problem, rears - eh, not so much.
Archive Gatekeeper
Yes, pulling the rear swaybar is a LITTLE more involved.....
The rear sway brackets are a PITA to get spread apart with hand tools- I ended up grabbing them with two pairs of hose grip pliers (http://www.harborfreight.com/cpi/cta...emnumber=37909) so I could spread them wide enough to slip them off the bar.
They clean up ok in the blast cabinet:
Just for giggles, I threw the rubber bushings and the exhaust hanger rubber in the blast cabinet and glass beaded them- they clean up nicely and I swear are softer now. Not bad for 18 year old German rubber:
