928 Forum 1978-1995
Sponsored by: 928 Specialists
kickdown issues
Old Sep 21, 2009 | 06:19 PM
meracus's Avatar
meracus
Default kickdown issues
hi
is there a tweek to make the kickdown on an 86.5 a bit less vague , its starting to annoy me a little , the process seems to be a bit impredictable
regards
andre
Old Sep 21, 2009 | 07:35 PM
davek9's Avatar
davek9
Hi Andre, please tells us a bit more about what your looking for "make the kickdown on an 86.5 a bit less vague", this post /statement is a bit vague.
And yes there are mods for the Auto's kick down, one to make it always start out in first (valve body) and another much easer to extend the switch from the floor to a push button by the shifter.
Did you try an advanced search on this fourm for Auto kickdown?
hope this helps
DaveK9
Old Sep 21, 2009 | 07:49 PM
86'928S MeteorGrey's Avatar
86'928S MeteorGrey
Yes, more information please. Controlling the "feeling" or action the kickdown, can be accomplished in a number of ways. If the vacuum line is leaking to the tranny, it will cause harsh shifts. The tranny cable can also be adjusted to eliminate shifting "irregularities"... Make sure all the slack is out. It's a trial and error proceedure...
Old Sep 21, 2009 | 09:02 PM
BBX's Avatar
BBX
This is an interesting post. There should be an "Official Automatic Tranny Mod thread".
Old Sep 21, 2009 | 09:09 PM
Gtaebr's Avatar
Gtaebr
I have an 86.5 and have it adjusted so that when I floor the pedal there is a very definite "Stop" at the kickdown switch. Push harder and "click" kickdown engages it is not vague in any way.
Mine also starts out in first from a stop I think all 86.5's do isnt it only S4's that start in 2nd?
Old Sep 22, 2009 | 02:10 PM
meracus's Avatar
meracus
sorry , ill try to be more precise
you put your foot down and it does nothing for a few seconds ....... then it kicks down
sometimes 2 seconds ,sometimes 5
