Megasquirt or MoTec?
Thanks Colin.
Good point.......
I didn't know that..........
That I did know about Megasquirt but didn't think it was too significant.
Ok so far I want a system above Megasquirt but not to level of MoTec.
What's an easy to program & tune mid-grade EMS system? Lots in this thread to examine.
Anyone selling a system?
HTML Code:
the MoTeC but while it might have great support my problem with it is that you buy the base unit at X $$$ then if you want more features you have to phone them and give them more money to unlock things that are already in there
HTML Code:
The thing that I don't like about MS is that it doesn't have dedicated knock control.
HTML Code:
It also has a wideband controller built in, which means you don't need tech edge, or the LC1 or any of those other controllers. This makes the installation cleaner
Thanks Colin.
Good point.......
HTML Code:
If you are good with wiring you should be able to get the wiring done correctly.
But the initial setup will be tough.
Otherwise consider Haltech or AEM as I have heard good things about both of them.
Almost Tom
I purchased Haltech E6X
http://www.haltech.com.au/index.php?...d=18&Itemid=15
Multiple Fuel Maps in 3D, Ignition Maps in 3D, input sensors are fuel and ignition modifiers. Windows base. Easy bar graph table adjustments.
Good support and has been around 10 years+
Good price for the universal kit: ECM, Harness, Intake and Coolant Sensor.
I'll document the install over the winter.
IMO if an aftermarket engine management system cannot provide sequential fuel injection, it's not worth moving away from LH/EZK with sharktuner, unless it's super cheap like megasquirt. The knock detection and individual cylinder retard capabilities of the stock EZK is really slick. I think my engine would be blown up by now with most other knock management systems.
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
What utter rubbish , the stock knocksystem while good in its day is over 20 years old , it is too old, to slow & picks up interference . If you are hearing the knocking you are already destroying your engine . Modern systems, the good ones are 32 bit, so they are already faster ,so there is not any comparison if they are tuned accordingly ,you are already ahead of the game . Tools are only as good as the idiots holding them. I wonder could you do your work with pc s from 20 years ago . I certainly couldnt.
There is no substitute for proper tuning , knock systems are only good enough if they are properly tuned . They are only an listening system, which is subject to all the interference and noise from the engine . If anyone has ever listened to what the engine is producing in the way of noise will know what Iam talking about .
Go to this link if you want to listen to some filtered sounds.
http://www.theknockbox.com.au/content/view/8/8/
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Comparing a 20 year old knock system to a 20 year old regular computer is just a silly comparison. You should be comparing a Cray from 20 years ago (something that was way ahead of its time) to today's computers. Yes, I could work on one of those
Dan
'91 928GT S/C
Hmm... perhaps you can provide a concrete example of why the stock system is rubbish? My car has over 40k miles on the supercharger install with EZK and now that I have a sharktuner, I can see how much knock retard was going on in all cylinders all this time (no ignition tuning was done until now). Since the car is still running great, that to me is a clear example of how *great* the system is.
However if you want to stay within the stock parameters using the limits of the basic maps as JDS have provided , then by all means you can .
Oh by the ezk picks up interference & is slow to pick up transient detonation & thus slow to react to it , particularly when the detonation is caused by oil ingestion .How do I know ? because I listen to it through devices hooked to the block through noise cancelling pilots headphones , specifically set up for the task .
On the Dynanometer foot control is quicker then relying on the ecu.
Hope I have cleared that up for you .
I would actually go micro-squirt on a system like this. Super cheap but you will have to develop your own sensors and look to spend a day or two on the dyno. We run it on our SCCA ITB race car. It's un-complicated with the VW in the long run and gained a bunch of HP's.
