928 Forum 1978-1995
Sponsored by: 928 Specialists
Danglerb vs. $2200 87 S4
Old 09-14-2009, 01:53 AM
no doubt
no doubt's Avatar
Don't start out by replacing parts. Instead, start out by testing. The *first* test to do is to spray 3 seconds worth of a $2 can of starter fluid into the air intake.
Does the motor start up with the starter fluid?
Does the motor start up and then die when the starter fluid runs out?
Does the motor still not start?
Answer those 3 questions and I can get your car fixed in moments...something that would be entirely random and lucky if you instead spend hours replacing various parts first without testing.
Old 09-14-2009, 01:56 AM
RED SHARK 1990
RED SHARK 1990's Avatar
Default cps
Hey Blithe the CPS unplug right by the maf just trace the wiring and disconnect it.The old connector might fall apart .When i changed mine did not remove fuel rail or fuel damper-just the maf out.
Old 09-14-2009, 01:58 AM
danglerb
danglerb's Avatar
Where do you find the cps 944 606 115 00 for $58?
Old 09-14-2009, 02:04 AM
danglerb
danglerb's Avatar
The earlier condition was no spark, hence the replace the cps idea. Now it starts and can be kept running by pressing on the throttle, so no point in starting fluid.
My guess is that now it just needs the usual freshening up, vacuum leaks, idle stabilizer valve, maybe a shot of Dr Bob's new cleaner rig, cleaning grounds, changing fluids, the usual.
Old 09-14-2009, 02:17 AM
UncleMaz
UncleMaz's Avatar
BMW's of the era use the same sensor as the 944 (don't know about the 928 specifically). It is part number BOSCH 0261210003. It can be found at Pelican, Paragon, Autohausaz or your local auto parts store. The range in price is from 46-70 bux. I believe they are slightly longer than the Porsche counterpart. All of the 944 guys buy them. Here is the Bosch parts cross reference site: http://ecat-online.bosch.de/toc/frame1.html
Old 09-14-2009, 02:51 AM
danglerb
danglerb's Avatar
BOSCH 0261210003 seems to be the OEM Porsche part, and slightly cheaper versions with longer cords for BMW etc are BOSCH 0261210002 and BOSCH 0261210001.
928 and 944 seem to use the same part 944 606 115 00.
Any similar leads for ISV? I don't recall the details of which version Autozone had cheap.
Old 09-14-2009, 03:56 AM
no doubt
no doubt's Avatar
Autozone has the cheapest Porsche 928 ISV price, but the catch is that Autozone varies the price based on your zip code.
35210 will get you a cheap ISV.
Old 09-14-2009, 04:14 AM
danglerb
danglerb's Avatar
Says $140 on the ISV for a Duralast, looks funny to me.
OTOH now that the car is running, the point isn't to restore it to like new condition, its to sell it. See how that Cherry Red paint polishes out, clean it up, fix the obvious vacuum leaks etc. and leave some fun for the new owner.
Old 09-14-2009, 09:42 AM
69gaugeman
69gaugeman's Avatar
pm sent
Old 09-14-2009, 10:59 AM
UncleMaz
UncleMaz's Avatar
You are right, but you get the idea. Sorry, for copying the wrong number.
Quick Reply: Danglerb vs. $2200 87 S4
