I need a part
I put the out the word to a couple vendors but I did not get a response. I need the heater hose connection that bolts to the right side head. The one I need has a provision for a thermo switch. The one pictured has had the 90 degree pipe cut off and blocked but you can see the thermo switch in the picture.
I have a new switch coming so I don't the switch. I will be cutting off the tube and capping it like the one pictured.
The reason I need a replacement is because I cut off the chunk of aluminum off and eliminated the sender. I now want to add it back in.
If you can help send me a PM.
TIA,
Rick Ollah
MN
TIA,
Rick Ollah
MN
I have one. It's actually a common part, US 78/79 cars have a temp-activated vac switch there for EGR. I had intended to use it near the #8 cylinder to add a sensor for other reasons, but it doesn't fit with all of the CIS piping in the way.
Anyway, PM your address and it will be on its way tomorrow.
