85-86 LH/EZF Pinout diagram?
Supercharged
Can someone please post the pinout diagram for the 85-86 LH/EZF connectors? I cannot find them in my documents or by using search.
I have a friend who is adding a nice little power adder to his 86 5-speed. Final output should be near 480CHP or 410RWHP. He needs to know where to get the RPM signal and the WOT signal.
Thanks in advance!
Thanks in advance!
Craic Head
Thanks in advance!
Thanks in advance!
I'd recommend that he get one of these from Porken too (called the Bridgit):
Instead of hacking the harness, you just put it in place and take the signals you need out of there.
I'm using it for my Innovate LM-1 to take a tach signal, the Idle/WOT and a couple of other things. He also has a diagram to take a fuel pump lead and ground off of there, so you don't have to put in a jumper in place of the fuel pump relay to energize the fuel pump for testing and/or to pressurize the system without cranking.
Oh, and 410RWHP? HOLY CRAP
Supercharged
Thanks Ted... Exactly what I wanted.
Mike- I'll tell him about it. That's a nice unit.
It's Friday boys. Almost time to salute the whatever needs saluting.
Thanks in advance!
Thanks in advance!
BTW I got all the plumbing sorted out last night, and ready to start her up, all i need to do now is the wiring
Craic Head
BTW- I don't know if this would be useful, but the LM-1 and the newer Innovate stuff gives you some programmable outputs, so you could set your own WOT switch if it would help.
I'm not sure what you're trying to trigger or why, but I think there's a way to set it so that the output (dry contact) closes when a certain threshold is hit, like a certain temp from a sensor or in this case when you reach a certain number of RPMs. I'd use an isolation relay instead of the internal one, but the setup would be pretty simple and completely adjustable.
1 Post
Not being a Dick Andrew. Sorry you can't handle the truth, or someone pointing out look harder. Pointing out things can be found if one spends time searching and looking. Yes, it is found with searches.
928 Engine Re-Re-Rebuild Specialist
If you didn't want to be a dick, you'd post links to the threads rather than dropping in here to tell someone "try harder".
