8v at the fuel pump
Hi Ken,
Given the results from my partial cleaning and "DeOxit" treatment on the fuse panel, I would suggest that this would be an excellent place to start if you're reasonably sure that the grounds are good.
Remove fuel pump relay # XVII and check voltage at terminal 30. If good, voltage drop is in fuel pump feed circuit. If same as at pump, check voltage at fuse 22. Hope this gives some direction.
On the Bandwagon
Many Thanks!
That's odd fuse 22 supplies terminal 30 of relay. You should test voltage at fuse, not across.Try to jump relay terminals 30 and 87, then check voltage at pump.
On the Bandwagon
