928 Forum 1978-1995
Sponsored by: 928 Specialists
85/86 Fuel Injectors
Old 08-26-2009 | 10:27 PM
danglerb's Avatar
danglerb
I used the google shopping search for, M-9593-aa302, and came up will all sorts of higher prices like this from Jegs.
Ford Racing #397-M-9593-AA302
# Fuel Injector Flow Rate: 24 lbs/Hr
# Type: EV6 (Jetronic/Minitimer Connector)
# Impedance: 11-18 ohms
# 8/pkg
More Details $289.99
Old 08-26-2009 | 10:50 PM
stolarzj's Avatar
stolarzj
I did the same and Jegs and Summit always seem to be higher then everyone. I settled on Roush-Yates figuring it was a well enough known company.
Old 08-27-2009 | 02:28 AM
zoltan944's Avatar
zoltan944
I just went to the dealer a couple of hours ago and picked up my set. $189 plus tax. 2 places were listed one of them had em, guess we should be quick to poopoo the local guys? Ill have these suckers in by the weekend!
thanks for the link
Old 08-27-2009 | 10:05 AM
stolarzj's Avatar
stolarzj
I put the injectors into the rail, then Dremeled the extra groove into them. This seemed to work well, it gave me a stable place to hold them and spin them and it allows you to see the height they should be and quickly check the clip fitment.
Old 08-27-2009 | 05:58 PM
eatiles's Avatar
eatiles
Can you put a picture of the grove that you made? if possible. thanks in advance
Old 08-27-2009 | 07:15 PM
stolarzj's Avatar
stolarzj
Already installed mine, perhaps Zoltan can snap a quick shot. Basically if you compare the old to the new, you will see what needs to be done.
Old 10-20-2012 | 04:21 PM
davek9's Avatar
davek9
I'm looking for new Fuel Injectors 24#, looks like these are no longer available
However I did find these by Python and they look like our stock units.
Python
VENOM HP-624-8, High Flow, Maximum Performance, 24 LB/HR Flow Rate, Fuel Injector Set of 8
by Python
• Precision balanced set of 8, 24 LB/HR performance injectors
• Designed to support up to 310 Horsepower
• Universal fit for grommet style, multi-port applications
• High impedance (Ohm) coil
• Used by top, professional race teams, not for street use
http://www.americanmuscle.com/vehipefuin24.html
Around $255. per set of 8 @ Summit.
Three of eight of mine are leaking where the plastic meets the metal base.
Looking for any suggestions or comments?
Thanks DaveK9
edit:
This is the latest in stock 6 hole I could find, looks like the grove will still need to be cut, could not find dimensions.
Ford Racing part #M-9593-LU24A
http://www.blueovalindustries.com/en8810kit.html
Old 11-18-2012 | 03:54 PM
Edward King's Avatar
Edward King
Might be a little late -- but I'm planning the winter work on my car, and researched the injectors.
From what I see, the attached PDF has some good information on the Ford injectors -- with dimensions. It looks like there are adapters for the Jetronic style plug, and for the fuel connector (EV6 body style).
There's also a nice example of fuel flow rate for a 300HP engine -- they calculate out a needed 18.8lb/hr per cylinder for 300HP.
Hope this saves someone time!
File Type: pdf
Old 11-18-2012 | 04:24 PM
928NOOBIE's Avatar
928NOOBIE
I saw on another post that for the 85/86 these have the upper groove for the clips?
http://www.fiveomotorsport.com/merce...ors-0280156013
Old 11-18-2012 | 07:19 PM
Landseer's Avatar
Landseer
This is a helpful thread for 85/6 and for S4
https://rennlist.com/forums/928-foru...e-ii-info.html
Quick Reply: 85/86 Fuel Injectors
