Why cant anyone give a straight answer
#49
you may laugh, but I bolted an old 928 window sprayer motor on top of a large clean tank full of trani fluid. Then added 12 volts to the sprayer motor and pumped the ATF fluid into the tani with a long hose. It worked, but the little window fluid motor overheated right at the end of the job. Maybe there's a way to find a better pump because doing the hand pump with 1 quart at a time is just exhausting and takes forever.
#50
Can't you buy it in the gallon bottle? I used a hand pump and a gallon container to do my 5 speed. It was actually one of the easiest jobs I ever had to do on this car.
#51
Chronic Tool Dropper
But the original question was why nobody could tell him how the factory did it. Why couldn't anybody tell him how the factory did it?
