AC pully separation ... boggles
Rest in Peace
The front plate on the AC compressor had the nut come off and then the plate.
The pulley is still intact, and there is a spacer washer still on the shaft. What other internal parts on the shaft could be missing? If the washer is all that is present, then I just need another nut, lock washer, flat washer to put it back together?
Under the Lift
Andre:
There are usually one or more very thin spacers/washers under the outer clutch plate. I see you have one. You want an air gap of 0.5mm after the outer nut (just put a lock washer under it - no flat washer) is tightened. So, you may need more thin washers. Torque the nut to 18 ft lbs.
