Does Driver Weight Effect Dyno Output?
No, Mark, never have done it on final or close to the ground, had a very good friend do it once when a seat track broke.
My point is was I wanted to know if you had any knowledge of flying, you have answered that question in your usual way.
I think we know what happened now. again, if you define "flying" by just a moment in the air, above the ground, for some smalll duration of time, yes, he could have been "flying" at low air speed (not 0) for a brief time. He even said, he traded altitude for some air speed, and then landed. pretty tough to have no air flow over the wings, and the thrust from the prop doesnt count for much.
Blown, yes, ive been flying off and on for 30 years. we had a couple of planes in the family growng up. Ill have to post some video of some high speed flybys in a pumped up Aerostar. Anyway, no much at all in the last 10 years. Anyway, what is your point? anyway, you are doing tail slides on final approach or landing?
mk
mk
Greg, R
Regarding relative wind, I think you might be the one that is confused. The angle of attack IS the cord line vs the angle difference to the relative wind. Hey, i know what you are trying to say and I think you know what I was saying as well.
Basic stuff.
mk
Basic stuff.
mk
Mark, any pilot that has ever done a tailslide has done 0 airspeed.
And yes, I have done them in the Super Decathlon and other types.
You are also getting "Relative wind" confused with other things, it has nothing to do with the movement over the ground.
If I recall, relative wind is the difference between the chord line and the angle of attack, but it has been many years since I did the ground school stuff instead of trying to figure out how to make all these things work with out thinking.
Greg
Greg
Been a very long time for me to remember stuff like that Mark.
That is why I said if I remember right.
I just looked it up on Wiki, copy and paste.
The angle between the chord line of an airfoil and the relative wind defines the angle of attack. The relative wind is of great importance to pilots because exceeding the critical angle of attack will result in a stall, regardless of airspeed.
and yes we both know what each other is trying to say, but you are saying that you will never see a true 0 airspeed and that is where we do not agree.
It can and does happen, but only for a fraction of a second.
My biggest problem is getting my feet to work when they should, I just have not done enough acro to have it be second nature and most likely never will.
Some things are easy for some folks, but I can not do a good 8 point roll to save my life.
BTW, the Ted Smith Aerostar is one of the best looking twins ever built.
I know, i was nit picking!
I just did a google and just found that too.
I never said you willl never see "0" air speed, I said you will never see "0" air speed and maintain altitude, and on top of that, you cant see 0 altituded and have 0 ground speed, with 0 windspeed. of course you can see 0 airspeed, if you are falling or starting to fall.
accelerated stalls. very dangerous. (stall, even with any air speed if the angle of attack is too great) . thats what kills a lot of folks in aerostars! thin wings, fast planes! Like flying race cars!!
Im with you on rudder input, but that is probably just lack of experience, (not good doing slip and crab landings, though I cant coordinate with model airplanes either, and ive been flying them longer.
mk
mk
I hope not. the factor is so low, it can only mess things up if it is an added factor. ever see the dyno guys us their foot to move the drums with the car in neutral? thats the rolling force. like i said, all of the variables added together are only 20hp at 150mph down to 10hp at 80mph. If you could change that friction by 10%, which would be HUGE, that would be 2hp at the top and 1hp at the the bottom. not even worth thinking about. Ive tried lowering air pressure, raising air pressure, strap down tight, lose, etc, and nothing changes the out put when we get to the point of overlapping runs. Look no farther than rolling friction changes for just adding weight. Its less than a rounding error in the entire skeme of things.
Someone want to take a shot at plugging the numbers in?
24" diameter (keep it simple at 1ft radius), 50lbs (big 18" rims with 305 tires), assume even weight distribution.
Acceleration over 7 seconds from 1000rpm to 2000rpm. assume constant torque (rising hp with RPM).
This would show the total effects, measureable on the dyno in 4th gear with our cars on a dynojet, in the 300 hp range if you take that value X 2 for two wheels and tires.
Then, pull out 10lbs and see the savings.
Any takers?
Any takers?
Any takers?
Any takers?
Equations:
Torque: T = Iα
α=angular acceleration (radians per sec^2)
I=moment of inertia of a disk = ½ M R^2
M=mass (lbm)
R=radius
Power: P(hp) = (T(lbf*ft)*RPM)/5252
With numbers:
α=1000RPM/7sec= 1000RPM*2πradians/60sec/7sec=14.96 rad/sec^2
M=mass in slugs=lbf*sec^2/ft
. 100 lb wheel: M = 100 lbm
. 80 lb wheel: f M = 80 lbm
. 100 lb wheels: I=.5*100lbm*1ft^2=50 lbm*ft^2
. 80 lb wheels: I=.5*80lbm*1ft^2=40 lbm*ft^2
R=radius=1ft
Torque: T = Iα
. 100 lb wheels: T = Iα =50 lbm*ft^2*14.96 rad/sec^2 = 748.0 lbm*ft^2 /sec^2
. 80 lb wheels: T = Iα =40 lbm*ft^2*14.96 rad/sec^2 = 598.4 lbm*ft^2 /sec^2
. Converting lbm to lbf
. 100 lb wheel: 748.0 lbm*ft^2 /sec^2 * sec^2/32.2ft=23.23 lbf*ft
. 80 lb wheel: 598.4 lbm*ft^2 /sec^2 * sec^2/32.2ft=18.58 lbf*ft
Power at 1000 RPM used to accelerate the wheels:
. 100 lb wheels: 23.23 lbf*ft*1000/5252=4.427 hp
. 80 lb wheels: 18.58 lbf*ft*1000/5252=3.538 hp
Power at 2000 RPM used to accelerate the wheels:
. 100 lb wheels: 23.23 lbf*ft*2000/5252= 8.846 hp
. 80 lb wheels: 18.58 lbf*ft*2000/5252=7.077 hp
Excellent! A+ (extra credit for using both wheels as one)
so folks. copy this and show all your friends at dynos, over dinner, on the list. If you ever hear of any strange HP values gained by saving 20lbs of wheel weight, even though it was rotating, here is the HP gained on the dyno in probably near 4th gear. Now, these values will go up in lower gears, but on the dyno this is what you would see. 1-2 Hp! If you have more than this kind of gain on the dyno, its due to something else.
Thanks for doing and showing the work on that.
as a note, if you did have constant acceleration as you used, the engine actually would have a slight up tick in torque, without the wheels, right? But, since we are talking about dynoing, it really doesnt matter, because that is what the "to the wheels " forces would be and would register
Thanks again,
Mark
Thanks again,
Mark
Okay assuming you are running along a flat torque curve with constant acceleration from 1000 wheel RPM to 2000 wheel RPM over a period of 7 seconds the following shold determine the amount of power consumed in accelerating the wheels at the 1000 and 2000 RPM points.
Equations:
Torque: T = Iα
M=mass (lbm)
R=radius
With numbers:
R=radius=1ft
Torque: T = Iα
Equations:
Torque: T = Iα
M=mass (lbm)
R=radius
With numbers:
R=radius=1ft
Torque: T = Iα
I think there's something wrong here, or some unstated assumptions.
Power is consumed by the wheels accelerating. I don't see how fast the wheels are accelerating. Also, have you converted from Lbsf to Lbsm or slugs?
It might be easier to compute the total energy in the spinning wheel at, say, 150MPH and divide back by total time to get an average power consumed.
14.96 radians/sec^2 is the acceleraton rate
But this way, gives the HP at the rate of acceleration given, at 70mph and then at 140mph (approx speeds based on 1000rpm to 2000rpm wheel speed). It also assumes constant torque available for acceleration, in which case power will go up proportionally with speed.
I like this, because its a worst possible senareo. 7 seconds is MUCH faster than any of us would go from 70 to 140mph. also, its 10lbs per wheel and tire. even if you double the results for 4 wheels and tires, for net effect on the road, the HP effects are going to be sub 2 hp total, and MUCH less if a realistic acceleration is used. 400hp 928 might do 12 seconds from 70 to 140mph, so you can see the hp required for a much greater acceleration rate would be much lower. BUT, this discussion is the effects on a dyno. Over a 7 second run, the effects are in the example provided. we should have probably done a 3" , 25" diameter donut instead of a solid disc. That might triple the result values. In the end, that might be offset by the fact that our engines don't have flat torque curves to redline, so the acceleration rate would fall as RPM goes up, like a flat HP curve would. BUT, this example shown is just easier to understand and modify.
mk
mk
