928 Forum 1978-1995
Sponsored by: 928 Specialists
Cracked Frame! ARRRRGGHHH!!
Old 08-03-2009, 02:57 PM
  #46
Rob M Budd
Rob M Budd's Avatar
Good news.
Preliminary report from the frame shop after inspection.
"We see it quite often. It's a repair we do frequently on many models, domestic and foreign. Michigan roads do that to a car. The 928 is a solidly built car to say the least. It could have happened a long time ago and not become apparent until it opened enough to produce the clicking sound.
We'll clean the area & inspect it, stop drill, weld it, and then re-undercoat. The 928 has a strong frame & won't need a plate added. It'll be fine. We'll inspect the other side and the entire frame, just in case."
Old 08-03-2009, 02:59 PM
  #47
docmirror
Shameful Thread Killer
docmirror's Avatar
Excellent. You'll be on the road in a short time.
Old 08-03-2009, 03:13 PM
  #48
M. Requin
M. Requin's Avatar
Rob, when this is done let us know the outcome and, if you don't mind, the cost. I think it would be a useful addition to the thread. And congrats btw on your good fortune in it being a relatively simple fix!
Old 08-14-2009, 10:47 AM
  #49
Rob M Budd
Rob M Budd's Avatar
Got the 928 back from the frame shop. Upon removing the undercoat, turns out the cracks were small. The clicking sound was the result of a bad weld spot on the radiator cross member. Upon braking it would move just enough to make the noise.
Welded and re-undercoated. The rest of the frame checked out OK.
Repair cost was $300.
Took her out last night for some spirited driving. Like all 928s, it drives like it's on rails.
Old 08-14-2009, 10:50 AM
  #50
heinrich
928 Collector
heinrich's Avatar
Rob, that is excellent news I'm happy for you
Old 08-14-2009, 01:07 PM
  #51
Richter12x2
Richter12x2's Avatar
Yeah, definitely! Glad to hear it wasn't anything serious!
Old 08-14-2009, 01:31 PM
  #52
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,554 Likes on 1,433 Posts
Rob I would also suggest that you do more inspection of the rails, I would remove one at a time the lower control arm boltsif you find that any of them are wet then i would drill a few small holes on the underside of the rails to let out water.
I isnt uncommon to find these bolts wet, from the picture there may be standing water in the rail.
If the bolt wont go back in then chase the threads and wire brush the bolt, put grease on the bolt to slow the corrosion.
Glad you got it welded back together
Old 08-15-2009, 02:47 PM
  #53
inactiveuser1
inactiveuser1's Avatar
Years ago I was told by one of the guys at Porsche when they used to have toll free number on info that I shouldn't put 17" wheels on a 928 as the frames could crack so always stayed with the stock wheel setup.
_________________
87 S4 auto
Old 08-15-2009, 02:56 PM
  #54
inactiveuser1
On last post that was if putting 17inch wheels up from 16inch on 928 S4
they said could be prone to cracks to keep stock wheel setup.
Wonder if they had larger diameter wheels on the car?
Old 08-15-2009, 04:31 PM
  #55
M. Requin
M. Requin's Avatar
Rob, tnx for the update, and glad it turned out to be not so serious! And Stan, thanks for that info on the rails. This all gets added to the file.
Old 08-15-2009, 07:10 PM
  #56
Benton
Benton's Avatar
Great news!
Old 08-16-2009, 02:49 AM
  #57
Richter12x2
_________________
87 S4 auto
You're joking. Even from a physics point of view I don't see how that would matter.
Old 08-16-2009, 04:38 PM
  #58
Randy V
Randy V's Avatar
I'm not saying that's a fact, but less tire sidewall does translate additional forces to the suspension and frame.
Old 08-16-2009, 04:48 PM
  #59
Richter12x2
Maybe, but probably not quite as much as driving 20 mph over the speed limit.
Quick Reply: Cracked Frame! ARRRRGGHHH!!
