Cracked Frame! ARRRRGGHHH!!
Definitely fixable, Rob- do not despair! A good welder can do that for you without much trouble. In fact, most good body shops have that capability...
But if yer gonna scrap it- I'll take it off your hands...
Steve
Steve
So I guess I'll keep it for a while.
Through a friend I found one with the frame jig and the sense enough to know a Porsche is really just another type of automobile.
928 Engine Re-Re-Rebuild Specialist
That crack doesn't even look serious. I've seen huge gaping holes on 240z's repaired and straightened back to "better than factory" straight... 240z race cars are really bad about seems coming apart. Yours looks like a very minor crack.
I would be looking for internal corrosion that might have weakened that area.
I'd probe the whole area with a center punch and a hammer to find thin spots. If it's rusted from the inside you will need to section it and weld in new material. If it's solid, stop-drill the cracks and weld them up.
just my .02
just my .02
And it looks like another may be under an area where the undercoating has begun to bubble up.
I'll get it repaired and keep an eye on it.
