WTB: 12 way seats that Paul Champagne can convert into 12 way Sport Seats
Not the sharpest tool in the shed
Anyone have a pair? I'm thinking about putting them into my 91 S4. Currently have the standard seats. Are there special things that need to be considered to do this swap.... things electrical?
Yes I know they are heavy. Part of the reason I am stroking the engine with Doc Brown is so there will be no performance issues. I've already done the sunroof delete. That probably will make up the difference in the weight of the 12 way seats.
928 Collector
There is no such thing as 12-way Sport Seats.` That would defeat the purpose of lightweight sport seats as the additional motors would make them heavier than 8-way. If you're set on doing this insane thing, you can have the biggre bolsters welded onto 12-way boat anchors.
Former Vendor
And weight is not the only reason to have a sport seat.
Paul
Dan,
I'm pretty sure that even 8 way power sport seats were a rarity, and maybe not even made. Most sport seats I've seen only have two way power, with forward and backward, and seat recline angle being by "manual" control. Since Paul is doing your interior, he can make a set of sport seats, starting with a set of 12 way power "comfort" seats. I think you also would need the 12 way controllers that are under the seats, as I recall - one for each side if you want these to have memory function on both sides as well.
Gary Knox
Gary Knox
Former Vendor
Dan,
Gary Knox
Gary Knox
most 12 way comfort do come with memory. But you can keep all 12 way and drop the memory if you want. Then the seat are easy plug and play.
I will have some "naked" frames at OCIC to show everyone what goes into doing a sport conversion.
Paul
So anyone got any 12 way regular seats?
what things will Ineed to do to incorporate them. Are there extra motors, relays, etc. that need to be sourced for this to work?
Rest in Peace
Dan,
Gary Knox
Gary Knox
Dan,
Gary Knox
Gary Knox
Dan,
Gary Knox
Gary Knox
Sounding like it is possible but at what cost in terms of $ and potential future electrical issues?
Please keep the comments coming.
Rest in Peace
Hmmmmm, Thanks Greg. I don't mind doing something if it has moderate complications, but this sounds like there is much more to the process. Sounds like not only would I have to update the seats with the additional motors, perhaps do some massaging at the CE panel as well as perhaps source a different door panel switch for the memory buttons for the seats and mirrors.
I am not sure if there is a difference in the mirrors or not, but some one here will know.
You did GTS mirrors right? if so you should be set.
My bitch was at who ever switched wires around in my car instead of just replacing the seat memory controller.
