928 Forum 1978-1995
Sponsored by: 928 Specialists
Any tips on how to get steering rack boots in place?
Old 07-07-2019, 09:53 AM
jpitman2
jpitman2's Avatar
If you have the rubber 'spacers' on the tie rods (rings ~1.5" dia), and boots to suit, the small dia of the boot will go over the outer ball joint, so you dont have to remove them, and then dont need a wheel alignment. Had no trouble getting generic boots fitted.
jp 83 Euro S AT 57k
Old 07-07-2019, 10:30 AM
buccicone
buccicone's Avatar
Originally Posted by oz928s4
full lock is the go...they go right on
Discovered this after many times struggling. Felt stupid after I discovered this
Old 07-08-2019, 12:17 AM
NewToPig
NewToPig's Avatar
I can attest how many curse words are imvolved in this
cpierso (09-24-2023)
Old 07-08-2019, 03:45 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,418 Likes on 1,356 Posts
Pig you need a new driverside lower ball joint yours is aluminum
Old 07-08-2019, 03:52 PM
NewToPig
NewToPig's Avatar
Hello!
Yes passenger side I just did I/O tie rods, steering boot, ball joint & boot. Moving on to driver side now. Pics were more so before and after on the rack boot since it is such a pain.
Old 07-08-2019, 09:27 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
OK sounds good,
keep em flying brother
Old 09-24-2023, 02:05 PM
redantporsche
redantporsche's Avatar
I just replaced the tie rods on my 1984 928s. I couldn't budge the inner rod, but with a simple tool from amazon (
Amazon Amazon
), i was able to remove the inner rod in 3 secs. In terms of putting the boot on, i messed with it for a half an hour before putting the boot on as far as it would go and then turning the steering wheel until it locked. It then popped on simply tugging very easily with some pliers. Thanks guys for all the tips! Now for an alignment!
Old 09-24-2023, 06:39 PM
gbgastowers
gbgastowers's Avatar
Location: Holden Beach and Winston-Salem, North Carolina 82 928 Euro S 5spd MOSS GREEN/CHAMPAGNE-04 996 C4S CONV TIP POLAR SILVER/METROPOL BLUE
I use these bicycle tire change tools for the boots
Old 09-24-2023, 06:54 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
One end of the boot goes on pretty easy, to get the hard side on, turn the wheel to compress the boot you are working on, and with the boot greased up, it will fall into place with some assistance very easy..
Old 11-06-2023, 09:55 PM
Thomas Janzen
Thomas Janzen's Avatar
Default Inner tie rod boot installation
I fought with thise mthrphkrs for over an hour!
Get a heat gun and heat it up until you smell rubber ... hot! Spray inside with WD40 and if you have extra long pliers (like 18") and a longer flathead screwdriver, grip onto the lip of the boot with the pliers and finesse the other side with the flathead - *pop*, right on. It works best when the boot is hot, so work fairly brisk.
Good luck.
Old 11-06-2023, 11:41 PM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,473 Likes on 1,468 Posts
Honest story....
I had a mechanic who put his two index fingers inside the boots (180 degrees apart), pulled the boots over the steering rack, and pulled his fingers out.
The first time I saw him do this I was in pain, just watching.
He claimed that this didn't hurt, at all!
Perhaps worth mentioning, this mechanic always refused the Novocaine at the dentist, no matter what they were doing. He said drilling on his teeth caused no pain.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
Old 11-07-2023, 02:52 AM
Darklands
Darklands's Avatar
Received 1,147 Likes on 618 Posts
Hmmmm,
means no pain also no pleasure?
Old 11-08-2023, 01:00 AM
ZEUS+
ZEUS+'s Avatar
For stubborn rack bellows or cv boots, hot water works well. Put the desired end in boiling water for a minute or two. Wipe off any water, lube and install It will become more pliable and stretch easier without compromising integrity.
Old 11-08-2023, 10:30 AM
buccicone
buccicone's Avatar
Bill If you do turn the wheels to full lock you will notice that there is a continual cone shape all the way to the boot seat , its really easy to slide the boot on , no tools are necessary, In fact it almost looks like it was designed to be this way to facilitate boot installation, Try it you will see
Do this ^^^
The following 2 users liked this post by buccicone:
davek9 (11-08-2023), Mrmerlin (11-08-2023)
Quick Reply: Any tips on how to get steering rack boots in place?
