Kempf Tool High Side Setting? 32V
Ed and I re-tensioned my TB last night. All went well and I felt I was pretty prepared having read a much as I could about this procedure. The Kempf tool showed the belt tension was in the middle of the window. I checked this twice and almost left it as is because there hasn't been any warning light coming on. Cameron's mechanic did the TB/WP and used the 9201 to set the tension 2000K miles ago. Well I just can't leave things alone, so I moved the tension bolt about 1/4 of a turn (CW) and rechecked twice. Still in the middle of the window. About 1/4 of a turn more and the window was almost closed after turning the crank twice. After putting everything back together and driving home, I got to thinking how arbitrary set to the high side is. Now I have reread as many threads as I can till my eyes are blurred. What or where is the high side of the window? Is it 75%, 85%, 90%, completely closed or just a hair short of closed? The info on is all over the place. Is this a personal preference like blondes, brunettes, redheads, or a touch of gray? Am I just being too **** and paranoid here?
Inventor
Team Owner
I set all of the belts i do to the top of the edge on the Kempf tool, this should cross to the 9201 tool and be at about 5.0
H2
Received 1,679 Likes
My Kempf tool, when the window is closed, is 5.3 on the 9201 tool. 5.0 is about 80%.
I set new belts to "closed" (5.3) and retension to 80% (5.0).
FWIW.
FWIW.
Brent,
I've checked the Kempf tool with the 9201 tool about a dozen different times. On MY Kempf tool, 90% of the window covered is 5.3 on my friend's 9201 tool. I put a paint line on my Kempf tool at that point, and always reset the tension to that line.
Gary Knox
Gary Knox
Seriously, the Kempf tool was so easy to use and being a rookie, I just over thunk it. Good to know I'm in the window of clinically acceptable. (Bad pun) Peace of mind is not always uncomplicated for me and for that I make no apologies.
Team Owner
I tested mine to a 9201 and the top of the window is 5.0 I have the older style Kempf
I am about to do this for the first time on my 32V. I assume the "high side" is toward the closed side of the window.
However, not sure whether the tool I'm using is new style or old. I notice that the bent "ear" that holds the spring is bent well past 90 degrees. The tool shown in the instructions has a 90 degree bend. Seems to me the change in the bend would change the spring tension. What tool do I have and where should it read for correct 32 valve tension (My belt has less than 100 miles on it but my light came on after I took the engine to 5K a couple of times)?
Still hoping for an answer to my question above. I started the job today and my new (100 miles or less) belt is clearly loose. The indicator does not reach the window, about a window's width to the engine side. Sounds like I should adjust to nearly close the window (32V). I am still wondering about new vs old tool and the fact that the "ear" on mine is bent well past 90 degrees.
Tomorrow I adjust and re-check a couple of times. Good to know my warning light works!
Better watch it. That would be way too loose....If I understand what you're describing correctly, you could be walking soon and facing a huge repair bill. If my belt were that loose, I'd either adjust it correctly before driving or have it trailered until i could.
H2
Some comments from ancient history including data from man himself:
https://rennlist.com/forums/928-foru...ml#post1218779
Thank you Erkka and H2.
Yes my belt is loose. Light came on at high rpm (did not remain on). That is why the belt is now exposed and ready to be re-tensioned.
Sounds like the Finnish testers and Jay Kempf say the middle of the window will do fine. Others recommend nearly closing the window. Guess I will have to choose.
It was very helpful to learn that a little rotation of the adjuster makes significant change in tension. I had not known that. Thanks again.
Under the Lift
My understanding is the angle of that bend at one end of the spring on the Kempf tool is determined during calibration. I've seen different angles on different new Kempf tools. So, it's important not to toss the tool around or it may lose its calibration, even though Jay says it's hard to knock them out of calibration.
