X Pipe Install - Check Engine Light
MY 89 auto. Having an X pipe installed - mechanic indicated that the "check engine" light would probably stay on since we are taking the cats off and all the plumbing with it. Is this the case - is there something that can be done so this does not happen or is the mechanic misinformed. Appreciate any help on this issue. Thanks.
Under the Lift
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
X pipe installed along with all air pump, cats and assorted plumbing removed. Car sounds a bit deeper but not really louder. Can't really tell if it runs stronger at this point but will figure it out in a few weeks. Car ran great before.
