Hammer in North Jersey
which one is the LH and which one is the EZK?
They are marked, check the tags on the cover.
As I recall the EZK is slightly smaller and the one on the drivers side.
Here are my readings using meter:
Idle test - Pins 18 and 8 on EZK
No Throttle - 3.234 OHMS
Throttle - 2.905
WOT Test - Pins 18 and 26
Rest/Idle (No Throttle) - 3.234
Accelorator all the way down - 000.5
I disconnected the harness cable from the TPS and the OHM reading stayed at 3.234.
So, what does all this mean?
Throttle - 2.905
There are several ways to test.
With the connectors still plugged in, connect the negative meter lead to ground. Connect the positive lead to the test pin. Set the meter to read at least 12volts DC. With the ignition ON, you will see ~ 0 volts with the switch closed and some positive voltage when open. I have not checked this circuit, but many are 5 volts.
Or, another method,
With both connectors disconnected, meter set to Rx1 ohms and one meter lead on ground and other on test point, you will read ~0 ohms when switch is closed and infinity when open.
The idle switch will be closed at idle and open at very little throttle. The WOT switch will close at about 3/4 throttle.
Or, another method,
