Who has the best cooling fan kit?
#47
Chronic Tool Dropper
Pusher fans are always a challenge. Add the shrouding they need to be efficient, and you block noemal airflow a lot when the car is moving. You have to manage your expectations for those. Meanwhile, the Mistique/Contour option looks good. I remember Bernie posting about that fit several years ago now. That would be a no-brainer update for a failing mechanical fan, if you didn't want to fix the original.
#48
Rennlist Sponsor
Pins are labeled "+" (ground) "1"(75), then "2"(83) in that order and verified on Jeannie's stove :-)
All of our 78-86 SharkBlade Fan Kits now use this switch instead of a temp probe thanks to Hammer!
Thanks again Hammer!
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
#49
Great information. Thanks
I just ordered this exact sensor yesterday.
Again thanks.
#50
FYI, I just installed a Wahler 75/83 version today (951.606.481.00) and the Middle Pin is not the Ground.
Regards, Hammer
#51
Ken,
Can you pass on your experiences with the SPAL twin 11" fan assembly please? Which radiator switch you used etc? How mounted.....
thanks,
jp 83 Euro S AT 52k
thanks,
jp 83 Euro S AT 52k
#52
The Wahler #'s now, as I can find them at least through my shop are:
Wahler 251 959 481 75 75-70/82-77c; 3 Point 75/82 Degree
Wahler 251 959 481 K 85-74/93-82c; 3 Point 85/93 Degree
Wahler 191 959 481 C 95-84/102-91c; 3 Point 95/102 Degree
Just thought I'd update for anyone else that may be putting electric fans in to replace the belt driven one, and wanted to use the existing switch location.
#53
supercharge temp
Hi David
This is Tien from Taiwan,I am interesting to buy the supercharge kit from Murf, before I buy it, I have to make sure the temp will not be a problem, since you have change to 16" fan, how is your engine temp normal and out side temp is???
Because Taiwan is very hot, our summer will go up to 37~40 C in hot day.
Sorry to ask such a question, I hope you can help me and give me some idea.
Thanks!
Thanks!
I have very limited space issue on the '87. The 16" fan is mounting in front of the A/C condensor and in total I have less than 4" of clearence.
To date I have tried two Zirgo Fans and on one the shaft striped apart from the blade (this one being their Ultra HP model) and the other was a puller design that was not that high rated to begin with.
I have moved on to Spal hoping for better results, but am always open for new and better options.
The Spal (pt. # 30102047) is a pusher design and seems to move more air than the Ultra Zirgo. (spec. reads 20amps at full draw) I have only had the Spal installed for a couple of weeks now and its doing a fairly good job of keeping temps. down in very hot weather.
