85 928 Throttle Switch Adjustments ??
I put in a new throttle switch of late and tried to set it to where the old one was set at. It is not working up to snuff though. Somewhere I have seen the adjusting info on this in the the blogs and just can not locate it.
Do any of you guys have this info on how to go about it??
wag
85s American Edition, 5 speed
wag
I think it may be on the 928specialist.com site
I believe you only need to set it so it comes off the idle click with little movement and that you get WOT somewhere around 80% of the throttle....
Craic Head
The WOT is not adjustable. If you adjust it so that the idle switch swings to open 'just off idle' then the WOT switch is also set (which does work out to be a little more than about 2/3 throttle or so).
