928 Forum 1978-1995
Sponsored by: 928 Specialists
clutch/trans question
Old Jul 15, 2009 | 06:30 PM
sharknoob's Avatar
sharknoob
Default clutch/trans question
If one is parked on a slight hill with trans in reverse and the clutch is pushed down to the floor shouldn't the car be able to roll??
Sorry for the dumb question but I think my clutch maybe hanging up because I could feel it sitting there on the reverse gear I pulled trans out of reverse with the clutch down engine off with some resistance on the stick and it rolled a bit after
Or does the trans axle lock up some how with the weight on it I have felt this very slight in my 944 but never in any other car
Seems to me if I push the clutch in it should unlock the drivetrain
Am I missing something?
Thanks Jeff
Old Jul 15, 2009 | 06:32 PM
mark kibort's Avatar
mark kibort
yes, clutch should release. int plate adjustment???
Old Jul 15, 2009 | 07:21 PM
sharknoob's Avatar
sharknoob
I used your axe and made a hole last month to check the H or T whatever we are calling them this month
I closed them up a bit still need to slowly down shift ...
Going to go try and find that slave movement measurement I think I remember it like being 25 or 35 mm
