Reproducing Door VIN Label + Others
Chronic Tool Dropper
The stock code label, the one that looks like a mailing label but has a barcode printed with a worn dot-matrix printer, is of some interest to me. I have the original still on the car and plenty of pictures but... The actual bar code is not any one that I can nail down. I can reproduce it in CAD but it will be tedious at best. Anyone have experience with these? Dan, it's the 15/16x2.5-ish label inboard of the VIN label in the doorjamb.
Not the sharpest tool in the shed
Any idea what is on these bar codes?
Craic Head
Hi DrBob - I have yet to tackle the door labels yet as I am still separate from my cars. However I have thought about the postal label bar code. CAD is over kill. I plan on using Photoshop to clean up (whiten the white and darken the black bars) on the photo I'll have of the label and will then print it out on an over sized Avery Label. I then use and Exacto knife to trim it to the correct size.
Use it in word or excel and maybe even autocad.
I'll have to look for 3-of-9 and see if it matches. Next to the barcode is the VIN, so I've been ASSuming that the code matches the number. I think the smog guy scans it so it can't be too exotic. It does need to support alpha characters though.
I downloaded it from the internet. If I get a chance I will see if I can find it.
You'd think the stamped metal numbers would be illegal to duplicate... stickers are just stickers, right?
The Shell factory-fill labels were used on all the cars, and should be readily available.
I found several 'freeware' code 39 fonts that I'll try on a sacrificial computer. Film in a week!
1 Post
Code 3 of 9 is alpha numeric and directional with a leading and trailing asterisk
to make a valid code with the font of ABC123 use the font in a word processor etc. and type *ABC123*
the one I use for our software product can be downloaded from our server here
