928 Forum 1978-1995
Sponsored by: 928 Specialists
Best Water pump?
Old 07-12-2009, 04:29 AM
worf928
worf928's Avatar
Received 1,643 Likes on 1,072 Posts
Originally Posted by Bill Ball
So, do we have a consensus?
Let's start a poll.
Old 07-12-2009, 07:31 AM
Sailmed
Sailmed's Avatar
Location: In the boatyard installing the mast and engine, we don't need a crane, we harness the mesquito's! Yeah!
Water is highly over rated - lets just circulate amsoil and the WP bearings will last forever!
Old 07-12-2009, 07:43 AM
Lizard928
Lizard928's Avatar
I will still use the rebuilds.
Old 07-13-2009, 12:46 AM
H2
H2's Avatar
I've replaced 3 pumps on 3 different cars...all Porsche new. I'm hoping someone comes up with a more secure design before my next WP job.
Where's PorKen on this issue?
H2
Old 07-13-2009, 02:09 AM
GregBBRD
Former Sponsor
GregBBRD's Avatar
Received 2,476 Likes on 1,468 Posts
Originally Posted by blown 87
The pumps that Greg and I had fail were new lasso's and both were adjusted with the 9201 and his failed very quickly, mine went about 3000 miles.
I used a Snap-On torque wrench and it was installed correctly with new everything that the belt touched and many things it did not.
For your and my failures, the pumps could have been installed with an impact and the belt could have been at 12.9 belt units and none of that stuff would have a thing to do with the impeller falling off. That's just a damn poor press fit. Laso certainly "changed" their design to compensate....on the "new" version. They use the same impeller and the same bearing, but they put a bushing into the impeller to tighten up the press fit. I'd guess that they have a whole bunch of impellers already machined, discovered they are too loose, and did the logical thing to "save" a few bucks....install a bushing.
I do have the tool done to fix the block. Just waiting for Steve to finish up the inserts and the insert drilling tool. I'll start a thread about this stuff, when it is all done.
Old 07-18-2009, 08:51 PM
JG928S4
JG928S4's Avatar
any more comments??
Old 07-18-2009, 10:02 PM
heinrich
928 Collector
heinrich's Avatar
Mattel make a cool pink one.
Old 07-18-2009, 10:10 PM
heinrich
928 Collector
heinrich's Avatar
The pumps that Greg and I had fail were new lasso's and both were adjusted with the 9201....
Personally I owned and used both 9201 and Kempf tools and the 9201 gave me inconsistent, non-repeatable readings evry time, so I sold it and love the Kempf tool, it works great.
Old 07-18-2009, 10:34 PM
blown 87
Rest in Peace
blown 87's Avatar
Mine gives me dead on, repeatable readings, we tested my 9201 against three of the Kemph tools and all three of the Kemph tools had different readings.
I can set a belt at 5.0 turn it 720 degrees check it again and it is going to be 5.0.
Not sure what to tell you other than no Pro mechanic that works on these cars that I know uses anything but the 9201 because it is reliable and repeatable.
Old 07-18-2009, 11:12 PM
H2
H2's Avatar
I have and trust my 9201 tool...but admittedly it's slower to use as compared with the Kemph tool. I've tested three Kemph tools against my 9201 and I had to mark my last Kemph wth a mark just barely aboved the notch. I kept thinkin I was getting bad ones. I use the Kemph for quick checks....but to the mark I filed on the tool..not the center of the factory notch. I think it's pretty well accepted, on S4s, that the proper setting is towards the high end of the notch. Set your belt to the center of the Kemph notch and you'll be running a bit loose. Obviously, it's not enough to make much difference but I think you have more of a safety factor by setting at 5.0 rather than lower.
Kemph and I corresponded on this a few years ago. With no complaints he didn't see the use in changing anything. BTW, the Kemph tool was developed while Kemph had a pre-85 928.
I also compared both gauges to the factory Porsche tool from which the Kemph tool was copied.
Where the 9201 really shines is tensioning the AC ribbed belt.
H2
Old 07-18-2009, 11:29 PM
heinrich
928 Collector
heinrich's Avatar
Glad you like the 9201 I sold you Harvey
Old 07-19-2009, 01:49 AM
Stromius
Stromius's Avatar
I am in process to converting to the Porken Tensioners so I guess I (will) have one surplus Kempf tool...and a tensioner (88) Anyone??
Old 07-19-2009, 02:00 AM
H2
H2's Avatar
I'm a little slow,Heinrich. I'm just now about to install the belly pan set you sold me! Keep the castoffs coming!
Harvey
Old 07-19-2009, 02:09 AM
blown 87
Rest in Peace
blown 87's Avatar
Harvey
Look on the bright side, you can work a 9201 correctly.
Old 07-19-2009, 04:04 AM
GregBBRD
Former Sponsor
GregBBRD's Avatar
Hmmm.
Quick Reply: Best Water pump?
