Part Needed: Passenger side exhaust manifold for 81
I can't see welding, somebody local must have some "spares", the upgrade to 85/86 is also worth it, and at the very worst somebody not local could ship.
Ends in an R so casting number.
I may have two sets, 79 and 84 Euro, buried in my garage, so I will compare them if I get a chance, but I don't recall hearing of any differences.
Administrator - "Tyson"
Location: No where Oklahoma AKA "The Dust Bowl" In The Arm pit Of Hell
Thanks guys for all the info. Good thing Danglerb's back since he knows for sure it's a casting number. Is it worth risking more broke exhaust studs to change to the 85/86 manifolds with the motor in the car.
IMO it's the best bang for the buck upgrade on a 16V car. Is the rest of the exhaust stock?
The only additional part you need is a spacer (about 1.5") on the passenger side between the stock exhaust and the manifold. Todd made me a spacer out of solid billet stainless, I could see if he has time to pop out another one quickly. If I had to guess, I would say about $100.
Some people cut off the stock exhaust below the flange and weld in a spacer.
I had to drill out 3-4 of the bolt holes on the 85/86 manifolds to fit on without a fight.
Ok guys here's the resolution to this situation. Sean found me a pair currently installed on a 84 US motor at Rogers 928 supply depot. Once again Roger and Sean save my day. Thanks for all the info and help on this. I'd be sunk without Rennlist and the knowledgeable people on it
One note: It also has the same casting #. Why in the world did Porsche make their casting numbers so close to their part #'s?
Bonus is I got my desktop back from him that he rebuilt for me. Love it when things come together. Thanks Jason
No thank you Sean. I always have a blast hanging out with you just wish it could have been a bit longer. As always Seans tech support is a life saver
I think everyone should send their business to Sean and Roger their a great team and do good work
Team Owner
Before you drive the car make sure to fit the block tabs to each manifold, if you dont have any then make some, the tabs are bolted through the lower bell housing bolts to one of the manifold /header bolts, this should keep the new manifolds from cracking and the studs from snapping off
Ok guys here's the conclusion. Got the new manifold installed and exhaust back together tonight. Car sounds excellent what a difference. I no longer think it's too loud it's now perfect.
