Where do I find info on factory stereos by year?
I have an ongoing quest to accumulate all of the original equipment for my
89GT. Where can I find out which stereos were avaiable for the 89 model year?
I currently have a kick-*** aftermarket system that was installed by a PO and although I would never install such a system myself, I have to admit it adds a lot of fun to highway driving.
I just want an original to put on the shelf with all the other parts needed to return the car to factory stock.
Maybe I'm going about this the wrong way.......
New question: Can anybody with an 89' that has the original radio tell what model blaupunkt it is? Maybe throw up a picture of it?
Archive Gatekeeper
Dave-
The hassle with stereos is that multiple options were available in each market each year, and I'm not sure if they're clearly documented in any factory literature. Sounds like a good project, since some day a functional, original radio will be worth more than any aftermarket unit, no matter how many dolphins swim across its faceplate.
Just found this site, looks like they list some radios by year. For '89 looks like they list either a Reno SQR46 or a CD-2:
http://www.autoatlanta.com/model/928-87-91/911-00.htm
The 311-mile 89GT looks like it has a CD-2 in it:
Dave my 90 has the CD-2 and its listed as a separate option. As noted, check the options codes to determine what your 89 came with.
Rob your right on the money with your comment on the working OE radios, the CD-2 is already worth more than most aftermarket stereo's with exception to maybe the real high end Nakamchi & Denon. I'm hopeful that someone will figure out how to fix the CD-2's which have CD Player issues and parts which are NLA. Mine still works but it does have ocasional glitches which scares me.
Archive Gatekeeper
Afshin-
Mine is exactly the same way, I pulled it while it still worked. It's going back in the GT at some point. The factory harness that connects to the CD-2 is also NLA, so once some stereo installer has hacked the wiring, yer done for originality...
From '89 MY yearly changes document:
Range of Radios In 1989 Models
M 158 Radio Reno SQR 48 - Standard only for USA/Canada M No.
M 326 Radio Berlin IQR 88 - Only C00, C10, C11 incl. booster
M 328 Radio Bremen SQR 46 - Only R.o.W., not C31, C32
M 329 Radio Toronto SQR 32 - Only C31
M 330 Radio Toronto SQR 46 - Only R.o.W., not C31
M 690 Radio CD-10 - Only R.o.W., not C31, C32
mandatory combination with M 494
M 691 Radio CD-2 - Only for USA/Canada
Radios with a CD player are now offered worldwide with restrictions (see list).
From '80 MY yearly changes document
The Porsche radio is available in 2 versions
Radio with 2 speakers in doors and 2 rear-mounted (standard) speakers
Radio with 2 speakers in doors and 2 rear-mounted speakers plus an amplifier (booster)
